98 c5 questions
Old Nov 2, 2023 | 11:46 AM
DaC5vette's Avatar
DaC5vette
1st Gear
Default 98 c5 questions
Could i put c7 headlights on my 98 c5 vette?
Old Nov 2, 2023 | 12:02 PM
killain's Avatar
killain
Oldtimer
Anything is possible, lots of $$$$$$$$ . . . . . . . But why ? Just go buy a C7 !
Old Nov 2, 2023 | 12:10 PM
Rziesk's Avatar
Rziesk
What he said! lol.
Old Nov 2, 2023 | 01:33 PM
yellow2007's Avatar
yellow2007
Money better used as a down payment on an early C7. I don't see it happening without major bodywork and electronic modifications.
Old Nov 2, 2023 | 01:39 PM
grinder11's Avatar
grinder11
C5 has an ironic headlight system. Because the stock lights suck. Ironically, the fact they are the last retractable headlighted Corvette makes them a desirable headlight setup for many, me included.
Old Nov 2, 2023 | 02:57 PM
c5arlen's Avatar
c5arlen
One should Not drive a General Motors Corvette at night... They are NG for seeing and dangerous for one's health!
Old Nov 2, 2023 | 06:12 PM
johnson-rod's Avatar
johnson-rod
It's OK to drive in Jersey with stock C5 headlights. All the roads are very well lit. You don't really even need headlights.
I commuted for years on the turnpike, the parkway and all the X95s and X87s and never felt I needed better lights. (I couldn't tell if they were on!)
I only needed headlights coming up the driveway. So I could see the deer.
Old Nov 2, 2023 | 08:22 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Apparently you've never been up north. Much of NJ is rural and very poorly lit. The GSP, NJTP and most of 80 are exceptions. Outside of the major highways it's dark AF.
Old Nov 2, 2023 | 08:28 PM
Johnny Hardcore
You sure could. 100%. And you should document the process and report back with your final product.
Old Nov 3, 2023 | 09:17 AM
grinder11's Avatar
grinder11
Old Nov 5, 2023 | 07:22 AM
d.moscatelli@comcast's Avatar
Yes the stock lights are not that bright. But instead of installing a system that does not pop up, think about using options such as the Sleepy Eye. You still get to use the pop up feature , it only pops up about a third of the distance as the factory set up and you get LED lights. They look way cool. Then there are also other LED lights that fit into the stock set up. But as stated earlier, the C5 is the last of the pop up/rotating setups and it would be a shame to dismantle that.
Old Nov 5, 2023 | 08:05 AM
yellow2007's Avatar
yellow2007
Originally Posted by d.moscatelli@comcast
But instead of installing a system that does not pop up, think about using options such as the Sleepy Eye. They look way cool. Then there are also other LED lights that fit into the stock set up. But as stated earlier, the C5 is the last of the pop up/rotating setups and it would be a shame to dismantle that.
No to the sleepy eye headlights. I think they look absolutely horrible. Yes to replacing the stock bulbs with LED's. That's what I did and the illumination at night is spectacular.
Old Nov 7, 2023 | 07:18 AM
Thanks for that feed back Yellow 2007. I can see from some pictures the LED's are brighter but you sayuing how great they are helps.
To 98 c5 questions
