1/4 Mile Help?
Old Nov 14, 2023 | 09:09 AM
grinder11's Avatar
grinder11
Originally Posted by jackthelad
And beware the rear end. A number of reported cases of the standard diff blowing when on the strip with high power and sticky tires. The only real fix is a C6Z06 trans and rear end.
The C6 Z06 diff has also ended up in pieces. Way back around 2006, Road and Track had a twin turbo Z06 built by LPE. It also spit its diff all over the track. The Quaife setup they went to in later years is supposedly superior to earlier stuff. But with enough power and traction, no part is exempt from failing.....
Old Nov 15, 2023 | 11:55 AM
NJShoreRR's Avatar
NJShoreRR
Sorry for the delay!
It went well for the most part. Didn't break anything, so that was a good thing!
First run wasn't so great. Dropped tire pressure to 22psi. Tire spinning all through the 60 ft. 12.48 @ 134mph,
Second run was a little better. Dropped tire pressure to 20psi. No spin, but definitely left way too easy. 11.26 @ 135mph.
Third run would have been nice, but lost traction in my shift to 2nd. Dropped tire pressure to 17.5. Cant find the slip, but it was 11.6.
Now I'm hooked and I cant wait till next season! Some of the guys at the track feel that since my trap speed was 135mph; if I can get the launch down and improve my 60ft, I should be low 10's. I'm sure an upgraded trans and diff would help give me the confidence to launch the way I should, but not in the budget this winter. Overall, a great day!
I appreciate the help and advice from all you guys.
Old Nov 15, 2023 | 01:38 PM
Beast's Avatar
Beast
Your car definitely has potential. My car is an auto, bolt ons with 3.73gears and 3200 converter. My best on street tires is
60 foot 1.97
1/8 8.0 at 88mph
1/4 12.5 at 111
wish I had sticky tires, maybe I’ll hit a 12.3???
keep us posted next season.
warm weather might help the 60foot.
Old Nov 15, 2023 | 01:56 PM
NW-99SS's Avatar
NW-99SS
2022 C2 of the Year Finalist - Modified
Nice first day - only 3 passes?
The mph shows potential for 10's no question. What were your 60' times for the 2nd and 3rd passes?
Old Nov 15, 2023 | 02:00 PM
NJShoreRR's Avatar
NJShoreRR
We almost had 4, but a Mustang hit the wall and they needed to clean up.
60' on the 2nd pass was 2.118.
Old Nov 15, 2023 | 03:35 PM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
Very cool! That's a solid 10.7 w a 1.7 60'
Old Nov 15, 2023 | 04:58 PM
NW-99SS's Avatar
NW-99SS
Agreed with above, figuring out that launch rpm and what tire pressure bites the best is the biggest hurdle as it changes with track prep and temps.
