I got LED headlights several years ago and they have never worked very well. One is out and looking to see if there is a better replacement. Like to upgrade to something that works. I got the LED''s from a vender on the Forum and not sure who it was now.
I have LEDs and while they're bright, they scatter light everywhere, indiscriminately. The light housings are terrible. I'm picking up a set of projectors from SharpLightInnovations.com to remedy the situation.
Hey Jack, are they better now than when I got these several years ago? Have any idea what the cost is?
Do you have JUST LED bulbs in stock housings or did you buy actual new headlights? Stock housing won't work well, they were designed for Halogen bulbs-Most guys buy headlight LED replacements and most are anywhere from 500--650 bucks for real HID/LED lights that work as designed.
All I know is that I have the replacement for stock. Been several years ago and i can't find what the order was. I had the local Dealership install them. I just went on Sharp Lighting website and a bit confused what I should get. I rarely drive at night, just need them to work properly.
Thanks Red. What I got years ago never switched well and just poor quality. Looking at the website that looks like what I need. They say easy installed and seem like not much of a problem to install.
If you rarely drive at night like you stated then to me spending close to 700.00 is absurd. My vette sits in the garage and I do not drive at night. If aimed correctly the ones I have are just fine. I recently installed led's on my 2020 Impala. (worse lighting than the vettes) And they mount in a specific way. If you do not then yes, the light scatters. Aligned mine work great
The ones I went with were the Oracle direct replacements.
They are designed to have a cut off in a retro lens and can be indexed. Not all bulbs are designed to do this. They also are of the new Gen that are fan less.
The only issue was you need added resistance in the system for the head lamps to close. That is an easy fix as I took a relay and used an extension harness. I cut the harness in half put the relay in and plugged it in. Everything works perfectly.
prices are reasonable and my light is much better.
Fact is I don't drive at night. But one is out and they've never switch good. Sometimes a delay and no lights until it kicks in. I just want something that works and know where to get it.
If you don't drive at night much and all you want are working lights, Is there any reason to not use original type lamps? Wouldn't they work 'normally' without issues? Or would this be too easy?.....
You could go with a name brand like Sylvania and get an ugraded 9005&9006 bulb.
You know I really am not a LED fan. I avoided using them for years as they were not always well sorted or worked well. Once I got the C5 the first time at night it was horrible. Just a yellow glow is all I had. I had already upgraded the DLR turns to switch backs to avoid melting the housings again as I just replaced them. If you have not looked your original housings are likely melted.
So I checked at work and picked up all the other bulbs as they were not that expensive. I avoided the Head lamps. Well I read a post here where the relay solved the close issue and I found the corec bulbs so they were just plug and play and not blinding someone.
This is a worth while move if you take the time to learn more about the bulbs and needs for the car. Just plugging in any LED is not the way to do it.
If anything replace the DRLs and use LED as you will find the factory bulbs destroy the factory turn signals. I have seen C5 cars with the bulbs that have fallen out hanging by the wires.
