Settle an argument: headers or final drive upgrade?
Old Jan 31, 2025 | 08:20 PM
SideOfTheRoad's Avatar
SideOfTheRoad
Default Settle an argument: headers or final drive upgrade?
So I'm new to the club of Vette ownership, and I was discussing future upgrades with a friend. I was considering upgrading the differential to a 3.90, he thinks headers would be a better upgrade.
Wondering what the consensus was here from those who have done either or both. Thanks in advance!
(01 manual, basically stock at this point.)
Old Jan 31, 2025 | 09:55 PM
jcgunn's Avatar
jcgunn
So...what do you want to do with the car? Drag strip, auto-cross, improved gas mileage, long distance cruiser, the Mojave Mile...
Old Jan 31, 2025 | 09:58 PM
hdrider1's Avatar
hdrider1
I'd vote for the 3.90 differential for sure. That'll correct the too high gearing and make 6th actually usefull.
Old Jan 31, 2025 | 10:00 PM
HeyFred's Avatar
HeyFred
3.90 rear gear.
Old Jan 31, 2025 | 10:41 PM
Hary Gahtoe's Avatar
Hary Gahtoe
Classic conundrum.
Here's a thought;
maybe start on repairs and bring the suspension for starters up to the level of performance before you add power
The internet is full of cars guys have spent $$$$ on while you rarely see well maintained with perf. enhancements cars
But;
If you want the best bang for your buck ( and ego) try a used Catback, Plugs, plug wires, K&N and a Tune.
Good Luck
Old Feb 1, 2025 | 08:20 AM
SideOfTheRoad
So, this is a street car. Not a daily driver, I want to have fun with it, mainly spirited/aggressive driving through the twisty country roads outside of the city. Track days are a possibility with a group of car guys. I live in Canada, so it will only be driven 6 months out of the year. It is currently hibernating in the garage, waiting for spring.
Old Feb 1, 2025 | 09:20 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Feb 1, 2025 | 09:25 AM
jmzvet's Avatar
jmzvet
I did 4.10s and LT headers about 6 months apart. The gears made a huge difference and best bang for the buck 20 yrs ago.
Old Feb 1, 2025 | 09:33 AM
SideOfTheRoad
Originally Posted by Hary Gahtoe
Classic conundrum.
Here's a thought;
But;
Good Luck
Fair point, I did not provide enough information on the car. Here goes:
Car has roughly 30,000 miles, nothing wrong with it, it has been a garage queen all it's life. The car has almost new Pilot Sports on the factory wheels. I have already begun some work on the car, with an additional list of things I will do in the spring that mostly require a lift.
Already done:
  • C7 shifter with C6 ****
  • Z06 Ti Mufflers
  • LMC5 module
  • LED lighting all around with hyper-flash harness and brake load resistors installed
Waiting for spring:
  • Tunnel plate upgrade
  • Katech remote clutch bleeder
  • Stainless steel brake lines
  • Flush/ change all fluids
  • Bilstein B8 shocks
  • AFE Johnny O'Connell Sway bar kit
  • CAGS delete harness
  • Anti-venom mod
  • Vararam intake
I also want to do the H-pipe mod and muffler bypass mod while I have the exhaust down during the tunnel plate and remote clutch bleeder install. I am weighing my options for exhaust upgrades while keeping my eyes open for deals. If I'm perfectly honest, I do like the look as well as the weight savings on the Ti mufflers, and the bypass mod seems to really improve the sound from what I've heard.
I also plan on getting a tune, and will be doing this sooner or later this year once things are decided and done.
While this is my first Vette, I am not unfamiliar with the cars. I installed all the mods on my friend's '99 convertible, and I was a GM tech at a Chevy dealer from '97-'14, and worked on countless Vettes. That being said, I am looking to the community for advice. I'm looking at all options for best performance bang for the buck for my setup and needs. All opinions are welcome.
Old Feb 1, 2025 | 09:54 AM
hdrider1's Avatar
hdrider1
I would suggest doing the gearing first - that will make a huge difference as mentioned earlier. It will be much more noticeable than the headers.
Old Feb 1, 2025 | 12:14 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
I'm with Mr Gahtoe's advice. I also want to bring my 2000 up to speed, no pun intended. Though yours is much lower mileage than mine all those suspension bushings are old and worn. Really want the car to feel lively again get the soft bits replaced first. I am deep into it now just spending over 2 G's on ball joints, tie rods and some cool Borg Delrin bushings. IMO car has to handle right before going faster not to mention the 100% improvement in handling and responsiveness.
Old Feb 1, 2025 | 01:37 PM
Beast's Avatar
Beast
Do it all. I have an A4 trans, LG longtubes, RPM 3.73 differential, 3200 stall, and a VR intake. It really wakes up an A4 C5
Old Feb 1, 2025 | 02:17 PM
JimmyC7's Avatar
JimmyC7
2nd Gear
You’ll get more use out of the headers after the gear change. Although I do agree with checking the suspension out.
Old Feb 1, 2025 | 02:22 PM
USAZR1's Avatar
USAZR1
For your particular set-up at the moment, 3.90 cogs would be the best bang for the buck.
Old Feb 1, 2025 | 02:23 PM
493lszosix's Avatar
493lszosix
I would do both but with 4.10’s
Old Feb 1, 2025 | 02:27 PM
ariZona06's Avatar
ariZona06
With the manual trans you've already got 3:42s and that's a pretty good gear for street and HPDE if you choose that kind of "track". I say go with the headers since you'll need them if you jump up to a heads/cam improvement in the future.
Old Feb 1, 2025 | 06:37 PM
bsn5440's Avatar
bsn5440
Headers add cool factor on the sound-gears will make a big difference on acceleration.
To Settle an argument: headers or final drive upgrade?
Old Feb 1, 2025 | 06:57 PM
I too would ensure that all the suspension pieces are in good working order.
Old Feb 7, 2025 | 12:15 AM
JMG2's Avatar
JMG2
Moderator
if the choice really is just headers vs gears, I'd go with gears .. and I'd do 4.11's , not 3.90s (I did 4.11s, they're awesome). you'll see a very noticeable difference in acceleration with the gears, and 6th will actually be useable.
headers are nice ..but without any other changes you won't see much of a difference. The ls1 (and all ic engines) is a balance of intake, exhaust, and combustion. You can't just increase exhaust without re-balancing intake everything else. Most people start with cat back, headers, intake, and a tune. That's where I started YEARS ago, and saw about a net 30hp/30tq gain on a dyno (of course it didn't end there, and now at 500+ hp with supercharger and cam).
again, depends on what you want -- headers are a nice platform to start building out your motor, but don't expect very much gains if that's ALL you do.
Old Feb 7, 2025 | 04:02 PM
c5arlen's Avatar
c5arlen
Do neither... Leave it alone
