Noisy Interior
The front floorboard is really thick and sturdy. I did mine, but came to realize it is probably not a source of noise. I did virtually every inch of my interior, including the halo. That exercise revealed a lot of noise leaks, the floorboard is the least likely.
Overview
[img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAA AAgCAMAAABEpIrGAAAAgVBMVEUAAAAQcP8IZf8IZ/8JZv8HZf8IZv8IZv8IaP8JZ/8HZv8IZv8FZf8YcP9FjP+TvP/g7P/////R4/9Vlf8QYP+Es/9kn/8IZv8nef8JZf8AYP/v9f/Q4v/B2P9GjP8HZv+yz//Q4/83g/8HZv/g6/+Dsv8HZf/n7//////////e6//ZLyHjAAAAK3RSTlMAEGCfz+//XyCQj98w/////////xD//6D/kBD/////7////8///5Cgz+/vONkvXQAAAPJJREFUeAF9kkUCwzAMBGVSGMrM3P//rxBaB+e6s0YREFJpw2y0cgS1cT3DQLmNWPjcwK/XA24RWIuEdg4j7OtHUX0NYedxko5+jCeZMc0En8F sVDDHSd1WDoFdIlogX46awopozWA+ythsd7s9Zxy mJBkcs3wcMZC0YHDKhDNbKLowuGYC21zINIWUbQ7 EwwJT7YogqgTTKaTY4tIp7HDIRadwwzVlKVyv11H G9cekFBxam8FbTInuQ4LCd3cL2Uzd+4UV/VkHfUIgMLRdQuBi7JsCxh5rQEAfrO9NYSWojruwB OOhDoR8PF+j0fuipNX+AmbCIviMIiwCAAAAAElFT kSuQmCC[/img]
[img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAA AAgCAMAAABEpIrGAAAAM1BMVEUAAAD+/v41NTUBAQEAAABZWVknJycWFhaZmZmIiIjp6ellZ WXMzMzX19eurq54eHhHR0dExXFyAAAAAXRSTlMAQ ObYZgAAAPtJREFUeAG8kAWOBDAMA9d1Sin+/7XXbpZZdBaURlMrhx28ycGCD/n0bvkBwJf8C+AoIvRAWGtMyHGtCWkfxW+DRopuuI jUtTQJDStevNoXWaRjRSllLd1O8FFhgEZx2BmkAm HC8HwpOUyxSA50VqOjXgAl50URvNWPBRcAnmwnhb cduthqQCO9KYTFBG7eDWoK1T47AZX9DuiUYT/TuhX3MGpnD51kPprSA9Dl+BCKl7jWHHEHmHsLWhN ZZMxPQCLTEuy+cYF6D9i8Q5e2Lcyz4AGwKdJbX0p 7AegC2qnvxAsAxQRAYH8J6Dg1a/lvpKRJinMW4cxLMPsDAJjSCaG8cPmnAAAAAElFTk SuQmCC[/img]
[img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAA AAgCAMAAABEpIrGAAAAilBMVEVHcEz/RQD/RgD/RQD/RQD/RQD/RAD/RQD/RQD/RQD/RgD/RQD+////PwD/OADr9Pbi6+73/f3K2+P7flzT4ugAAAL5ZTr2+Pj0uKzGy83+ThP70 cb7kXjc19frnY/+6+XajYHxck/Ro6M8LSr/WAAFFxz/bkioNhLTQCNkZWaCUELvGwDeWT6IfHsSwPnoAAAA C3RSTlMAyU9RouIMIvWPUzQQe5EAAAGkSURBVDiN hVPpeqwgDNWpjk5jWARxt9rZu7z/6zVAnWpv/e75g3JOCEkOQfDA/jkKU4A0PDztg3+RREQ+ECW/+QP8wmEdHq9IZAwhXhySpCuedW1rENJkg8cuIzTw o1ifD9e7IMHAAOK/7nc7Hz9FJuWA802Tdfz5ikoL0aP7s0miVf7rEQHN MDZeEFH/PIGuuEa9vamGUZWIXrEPnmxdjVLALtVL5vBSXRgo EhK1sxlYV9Jumy3QkrbsmL1mCKiyDSiEMEiBtVuC lkEawEPw+joT8xcJwAoqXsosG9/N4PeH92mkpeSVFaRUtuZSljcwxgsMmFuZSa7txOi SgJMopfw4nS5eMJ1OHxQhJmpF6BrpkvRKzX1Qqpc +AZX57AbMOUmk6GtCL6SUtNGha5RvdS8EbR0LhyN 9ctF/t9rloAHSBHldFOdzUdRcCK0V+mH5cbMxz3Mt6ntR 3Gti83xk87i9YdhU504jtF1rxRbWdpbDZui1I3Pd D94O8dq0DExXEToDLnxh69mVSJ6xZoENfo34P/zP09v9RUfb784+/93i+X8BtrYxyahtbccAAAAASUVORK5CYII=[/img]C5 Corvette floors are
innovative composite structures, essentially balsa wood sandwiched between fiberglass (SMC), creating a strong, lightweight, and stiff floor that's better than steel for weight savings, stiffness, and noise reduction. This construction uses lightweight balsa wood for core strength, providing excellent rigidity and sound dampening, a key feature in Corvettes from 1997-2004 (C5) and even into the C6 generation.
Special wrench for the Wife's Mustang will be in Saturday, 10-minute job and it will back in the garage and I can pull the Vette into my shop to do the window adjustments and begin some sound deadening.
Bad news - on the way back from the tire shop I saw some glare in the road ahead but couldn't tell what it was. Turned out to be 5 or 6 galvanized buckets, did the best I could, but one hit the lower spoiler and broke it, just inboard of the right-side wheel. Rear wheel made it perfectly flat. Looks like spoiler and spoiler frame/mount/brace are now added to the list.
Fact the factory 23-year-old tire vs the Michelins is great improvement.
I had previously mentioned it appeared as if someone had put adhesive or sealer on the outer regulator clamps. Well, as a Member mentioned it could be, it was not sealer, but the actual rubber from the clamp adhering to the glass. It took about 10 minutes each and a 0.013 D guitar string to separate the rubber from the glass. Got it aligned and tensioned properly and with the sound deadening I have no indication of noise from that side. I can hear some minor wind noise and roar on the driver side so next week I'll fully adjust the driver side window and install the deadening as well. Test drove it on various surfaces 70 - 95 and you could actually have a conversation.
It's quiet enough now that I can hear the sound from each direction instead of an overall roar. Side note; I installed a new window and lock switch as the original one was brittle and cracked. Small stuff, but it all matters.
Thank for the Info and Suggestions, it's getting there and is much more pleasant to drive.
Decibels accelerating moderately was in the 88-90 db range, steady state cruise at 55 mph was 69-70 db, sitting idle in my driveway was 52-53 db.
Not sure what some newer cars do, but seems pretty quiet to me.
I trashed my hearing way back in my teens and twenties, when I thought I was invincible, with too much top fuel and top alcohol starting line time with little protection, bad tinnitus.
I plan to do some better sound tests, get out on the interstate and see what a 70 MPH cruise shows.
Thanks for everyone's help and suggestions. What may not be an issue for some is very important to me.
I now play music at a much lower levels and need my surrounding quieter so I can enjoy life.
Can't test drive right now because the driver seat is at the upholstery shop having a scraped panel replaced and restitched, that I'm sure was from the previous owner struggling to get in and out. Tomorrow or Saturday I'll try to get to the rear compartment with deadening and foam mat.
Took it out for a test drive today and all I can say is it's like an entirely different vehicle than the one I drove initially. Up to 55mph is about the same level as 10mph, and from there to 80 isn't that much louder. I could easily hold a conversation if I chose at 75 or 80. The tires seemed to make the most difference, then the sound deadening (especially the doors), then the window adjustments. Now it's quiet enough I can detect some wind noise that I can't pinpoint the location (possibly the roof).
Bottom line - I've gone from wanting to turn it to thinking it's going to be very enjoyable.
Thanks for all the input and tips.
I mentioned I had hit a bucket. I was able to removes the right-side spoiler (air dam) and straighten out the sheet metal frame and put it back on. Can't tell it was ever damaged.
Truly amazing how much quieter these can be with some thoughtful changes.
