[Z06] Z06 vs. E46 M3 Race
Yes it was.
Don't get me wrong. We all make mistakes and the conditions were such that the driver was being tested more severely, but ultimately if you are driving the faster car and don't win, it is your fault.
The Z06 sounds much louder in the video because it's closer to the camera's microphone than the M3 is.
[Modified by Ryan Bell, 7:36 PM 1/9/2004]
Dude, I know you're a proud M3 owner and all, but there's no freakin way an M3 is as loud as the Z06 at WOT. I've heard both too, and there's no contest - its not just tone - the Z06 is LOUDER. I have a Z06 with stock exhaust, and where I live, there are TONS of M3's around - I see and hear them all the time. I've also seen and heard M3's at the track and at autocrosses. So I know first hand. There is one M3 in my apartment complex with an aftermarket exhaust which is pretty loud, but its not stock.
Closer to the microphone??? :confused: Watch that video again - near the end of the race, the cars are a quarter of a mile away from the microphone, and all you hear is the roar of the Z06. There is not one point in the race where you can hear the M3 over the Z06, except right at launch you can hear some of the rasp from the M3 for a second.
One of the car magazines publish the sound levels in decibles, but I can't recall which one does that, and I certainly don't have the time to look them all up. But if you do, I guarantee you'll find the Z06 is louder at WOT.
I had an M3 on order for 8 months, so I know quite a bit about the car. :confused:
[Modified by stingray454, 1:49 PM 1/10/2004]
From outside the cars, there is no comparison.
The E46 M3's sound is a higher pitch, and sounds very tinny.
It just seems to get drowned out beside the deep roar of a V8. :D
[Modified by tlaselva, 5:03 PM 1/10/2004]
As far as the video, it looks as though the Z was closer to the camera the entire race..if you know what I mean.:D
An another note, I'm looking to Supercharge my M here in the next 4-5 months. Should have around 460 crank HP when I'm done. I think after that a race against a stock Z06 will be just a tad closer.:cheers:
:skep:
[Modified by EOD_M3, 10:15 PM 1/10/2004]
Dude, how are you going to S/C that S54 reliably??? That engine is already at the outside limit of what the connecting rods can handle given the cylinder pressures it generates and the piston speeds under consideration. Obviously, these would not further increase since you are not changing RPM, but further increasing cylinder pressure seems unwise, even if it's only about 5psi as your Hp target suggests.
The issue with the S54 wasn't with the conecting rods, it was the rod bearings that weren't geting enough oil at *low* RPM's. BMW issued a engine oil pump and bearing recall for cars produced from Oct. 01 to Feb. 02 which pretty much took care of the problem. The S54 has never had issues with it's compression being too high, altbough that was most people incorrectly (and understandably) assumed was the problem with the blown engines.
How much is the Dinan kit? If they're offering a 50k warranty on the motor, then it must be BIG bucks - enough to cover an entire replacement motor with some profit left over is my guess.
With the amount of money you'll end up sinking into that thing, wouldn't you just be better off buying an M5? Or better yet, if you want to go fast, get a Z06! :p
Regarding the M5, they are routinely slower than the M3 in 0-60 and 1/4 mile, plus they weigh a ton and have four-doors. Not my cup-o-tea. Definitely interested in the C6 Z06 though. My plan is to S/C my M3, and then put a C6 Z06 in my garage right next to it a couple of years.:thumbs:
[Modified by EOD_M3, 11:18 AM 1/11/2004]
