[Z06] Why won't it hook?
Old Jan 25, 2004 | 03:07 AM
camarocasanova's Avatar
camarocasanova
Default Why won't it hook?
Went to track:
3100 ft elevation
13.12 110 mph
2.2 60 ft.
Big suck..Should go 12's, tried everything I can think of...Slicks are a must apparently, at LACR in Palmdale Ca....Any thoughts, suggestions, anything?
Got real loose in 4th gear at the top of the track once to. Scared the hell out of me.
I know by the mph there is more there, but damn, I am really upset at how hard this thing is to drive.
I had a 99 C5 and it hooked and went, although slower.
I only got 1 tenth more than last time when it had paper plates, and stock...Now I have 3k vararam, tstat, and a predator, I was hoping to get more. :rant:
Old Jan 25, 2004 | 09:03 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: Why won't it hook? (camarocasanova)
Maybe the track prep was bad. Maybe you need to properly heat the tires.
Old Jan 25, 2004 | 09:46 AM
z-u-later's Avatar
z-u-later
Default Re: Why won't it hook? (rbartick)
:iagree:
Old Jan 25, 2004 | 10:17 AM
slong's Avatar
slong
Default Re: Why won't it hook? (z-u-later)
:iagree:
What day? Were you their Sat. 1/24? It was also colder then a witches pointer too!
:cool:
Old Jan 25, 2004 | 12:51 PM
stano's Avatar
stano
Went to track:
3100 ft elevation
13.12 110 mph
2.2 60 ft.
I'm north of you in Lone Pine and it has been pretty cold... not good for traction :rofl:
Old Jan 25, 2004 | 02:51 PM
camarocasanova
It was on Friday, didn't make it to the corvette race on Sat...I know the cold probably has something to do with it, and the track was looking pretty crappy that night....I tried heating the tires once and it didn't do anything. I varied m launch in rpm and even tried feathering it. I guess the track was just bad that night, because I have never had the car move around like that in the higher gears either.
Old Jan 25, 2004 | 03:29 PM
ledfoot's Avatar
ledfoot
Here's a technique I use that may be of some help.
Late one night, take your car out for a drive.
Practice your launch technique at a four way stop or a traffic light. ..just as if you're at the drag strip.
The key is leave the line at a high rpm, ( which in this case is a stop light or four way ) without excessive tire screech.
I guarantee once you get good at this technique, your launch technique at the track will improve dramaticly,
I went from a 2.2 to a pretty consistent 2.0 to 1.9
I also drop my rear end tire pressure down to 24 lbs at the track.
good luck!
David In Indy
03Z-ripper
12.5/113/1.9
Old Jan 26, 2004 | 12:26 AM
landbaron's Avatar
landbaron
Default Re: Why won't it hook? (ledfoot)
Cold air & poor track prep did you in. IMO
Old Jan 29, 2004 | 04:42 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Mine does not hook very well either. I think I just need more practice tho. kaley
Old Jan 29, 2004 | 04:50 PM
painrace2's Avatar
painrace2
Have you had your car aligned? GM only checks one out of every 25 or so and then makes some adjustments. This is fine for tire wear but not for performance driving. I would suggest getting your car aligned with a GM Master Mechanic. Look until you find one then use him. Most races other than drag racing you will see the car with the best set up wins. Translated this means the cars with the best suspention to get the power hooked up through the tires. Newer tires = better traction.
Good Luck.
Old Jan 29, 2004 | 04:58 PM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Re: Why won't it hook? (landbaron)
:withstupid:
Old Jan 29, 2004 | 07:35 PM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Why won't it hook? (WisconsinVETTE)
Alot of valuable info in this thread. :lurk:
Old Feb 2, 2004 | 09:02 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Why won't it hook? (dubya)
It was really cold that weekend, I couldn't hook at Calispeedway.
To Why won't it hook?
