[Z06] First Time Drag time!
Old Mar 7, 2004 | 01:32 PM
brobopop's Avatar
brobopop
Default MY newbie DRAG TIMES!!LOL
well i went to the strip yesterday....first run i was really nervous and launched at low 1k rpm...it bogged a lot.2nd run i tried at 2k andpower shifted into 2nd..w/lots of wheel spin...3rd run was my best time when i launched at 3k rpm oh and i had forgot the traction control on. and after i shifted into 2nd ...lights came on for me to service my abs and traction control but after i restarded my car it all whent back to normal. What can i do to get rid of that wheel HOP?....I can't wait till i go back
1stRUN
60'2.247
I2-5.843
I3-8.696
I4-11.03
E.T.-13.096 at 110
2nd run
60'-2.313
E.T-13.1 at 114
3rd run with traction control on
60".2.207
E.T.-13.036 at 111mph
[Modified by brobopop, 6:33 PM 3/7/2004]
[Modified by brobopop, 6:34 PM 3/7/2004]
Old Mar 7, 2004 | 01:44 PM
bcmarly's Avatar
bcmarly
Default Re: MY newbie DRAG TIMES!!LOL (brobopop)
Excellent question. Does the suspension geometry need to be altered? Would fatter rear tiers help? Is there just too much torque at low rpms? Has anybody experimented and found a solution?
Old Mar 7, 2004 | 03:50 PM
ZO6Les's Avatar
ZO6Les
You can help wheel hop in a number of ways:
1. After lowering the car get a good 4 wheel alignment
2. Play with tire pressure and launch technique, i.e. practice a lot
3. Go with different tires e.g. drag radials
3. Install polyurethene bushings in the rear suspension
I did 1 and 2, but still had excessive wheel hop (and I am a fairly experienced drag racer), so I had the bushings installed, which eliminated 90% of the wheel hop, I now have drag radials and zero wheel hop.
Les
Old Mar 7, 2004 | 06:37 PM
blackz28turbo's Avatar
blackz28turbo
Default Re: MY newbie DRAG TIMES!!LOL (ZO6Les)
Thanks for the advice Les. I am ordering new bushings and end links for mine.
Old Mar 7, 2004 | 06:52 PM
ledfoot's Avatar
ledfoot
Les
I've also done 1 & 2.
Here's another helpful tip...
Push your left foot all the way down on the clutch...now quickly rev your motor up to, say, 2000 rpms . At this point, you want to slowly lift your left foot off of the clutch until you "feel" that the car wants to move forward. This is the aspect of drag racing you most want to be in control of.
You can practice this technique at stop signs and stop lights. The idea is to start from a dead stop with maximum excelleration and minimum tire screech.
As you get more better and more comfortable, raise your rpms up...some guys on the forum can launch their cars at 5500 rpms
Think of launching your car at the drag strip as if it were a sling shot...the more you pull it back, the stronger your times will be, provided you're able to get out of the hole with control of course.
This technique should knock at least 2 tenths of a second off of your 60 foot times, everything else , as far as shifting techniques, wheel hop...etc...etc.. I think is a lot easier to remedy...
and don't get frustrated...it took me all summer to get my 60 foot times into the 1.9 range...anything done well takes practice practice practice
good luck! :)
David In indy
Old Mar 7, 2004 | 06:55 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Work on your 60' times and the ETs will drop. If you are having a lot of trouble getting traction drop the rear PSI to about 28 or so and put some heat into the tires.
Just remember to have fun.
Old Mar 7, 2004 | 07:08 PM
robz's Avatar
robz
Default Re: MY newbie DRAG TIMES!!LOL (rbartick)
Lower the tire pressure and do a full burnout on the f1's to help eliminate hop. Do a search of post by Ranger, alot of good info. Have fun.
Old Mar 7, 2004 | 07:18 PM
pwrshhftd's Avatar
pwrshhftd
Default Re: MY newbie DRAG TIMES!!LOL (robz)
dont think I aggree with a "full burnout"
but i guess that depends on what a full burnout is...
anytime that I have ever spun the tires long enough to see smoke.. the car just blew the tires off. because the tires were too hot.
I have run a 1.75 on F1's before... i usually just spin them over a few times.. to clean them off. and i never go into the water.
My friend just got an 01 and i raced it for him a last weekend. it is bone stock, paper filter and all and i got a 12.31 out of it. but i noticed it wheel hops a good bit worse than my 02.
His car wheel hopes bad enough for the computer to cut power at times... i left alot of time on the table.. because the best 60' i could get was a 1.96.
Whats you guys opinion about replacing the 01 shocks with the 03 and newer shocks... thin this would help wheel hop?
les? Rb?
Also where are the busing that you speak of replacing? and where can you buy them?
[Modified by pwrshhftd, 7:23 PM 3/7/2004]
Old Mar 7, 2004 | 10:40 PM
RussBt's Avatar
RussBt
Default Re: MY newbie DRAG TIMES!!LOL (pwrshhftd)
I've never driven an 01 so I cannot help with this question. Good luck.
To First Time Drag time!
