[Z06] Another question about lowering
Old Mar 12, 2004 | 07:40 AM
TLM's Avatar
TLM
Default Another question about lowering
If you lower your Z as low as it can go with the factory bolts, do you need a four wheel alignment?
Thanks,
:confused:
Old Mar 12, 2004 | 10:11 AM
West Coast Chris's Avatar
West Coast Chris
Default Re: Another question about lowering (TLM)
Any time you change your suspension height you need to do a 4 wheel Alignment
Old Mar 12, 2004 | 10:32 AM
Piranha's Avatar
Piranha
:iagree:
Old Mar 12, 2004 | 10:48 AM
User 81424's Avatar
User 81424
The most notable change when lowering is a big increase in neg camber, so if you like the way it handles after lowering, and don't mind more tire wear then when you get it aligned keep the neg camber around -1 front and -.5 rear.
Old Mar 12, 2004 | 11:31 AM
GearGrinder's Avatar
GearGrinder
St. Jude Contributor
Default Re: Another question about lowering (CPT Z06)
Dead on info..after I lowered mine checked the alignment.It had .9 in the rear and .7 in front.
I think even if you dont lower it it would be a good idea to have it checked.
:cheers:
To Another question about lowering
