[Z06] Mud Guards
Old May 8, 2004 | 03:27 PM
MisterMissile's Avatar
MisterMissile
Cruising
Default Mud Guards
Anyone out there have any experience with Mud Guards: I'm looking for front and rears for my Z16. Thanks
Old May 8, 2004 | 04:16 PM
wstory1's Avatar
wstory1
Default Re: Mud Guards (MisterMissile)
:eek: If you must do it, get the ones that are molded to match the contour of the car. http://www.madvet.com/shop?frame=2.556
[Modified by wstory1, 4:21 PM 5/8/2004]
Old May 8, 2004 | 05:07 PM
Zeppelin's Avatar
Zeppelin
To each his own, but I say: :nonod:
Old May 8, 2004 | 05:36 PM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
mud guards?
uhhhhh...OK!
Old May 8, 2004 | 06:58 PM
Shylor's Avatar
Shylor
Default Re: Mud Guards (wstory1)
I believe those require drilling into you fender well. They aren't the kind that use the existing screw holes.
Old May 8, 2004 | 07:36 PM
Oyishdog's Avatar
Oyishdog
:crazy:
Old May 8, 2004 | 07:43 PM
PDCjonny's Avatar
PDCjonny
Default Re: Mud Guards (Oyishdog)
I saw those on a Vette at the Hooters gathering, don't know who's car though. I must say that I wasn't crazy about the looks of them, although they are pretty discreet. Then again, looking at how shi**y my black Z's fenders look from just two months of ownership, I can understand why someone would be interested in them.
[Modified by PDCjonny, 7:44 PM 5/8/2004]
Old May 8, 2004 | 07:45 PM
Shylor's Avatar
Shylor
Default Re: Mud Guards (PDCjonny)
I'm not a fan of them either but what are going to do. I wish GM would come up with a way to protect those areas of the body from road rash. Nothing looks worse than a Corvette all nicked up on those areas.
Old May 8, 2004 | 10:37 PM
ZratedC5's Avatar
ZratedC5
I installed the clear 3M sheets (custom fit) for mine from Cleartastic. I installed them behind the front & rear wheels, mirrors, and sills. Once you get the hang of it, they are a breeze to install and can be removed and re-applied as needed. See http://www.cleartastic.com.
Really does a nice job of protecting paint... I no longer grimace when I drive down the occassional road with chip-seal, a cheap way they pave roads here in Michigan.
Great customer service from Cleartastic, as well. I had one piece which had a wrinkled corner that wouldn't flatten out, and Cleartastic replaced it at no charge.
Old May 9, 2004 | 08:55 AM
jgmachine's Avatar
jgmachine
Default Re: Mud Guards (ZratedC5)
I purchased the painted versions of the ones above (yellow). The did not appear to "seal" close to the body of the car and look like poopie. I still have them in the box. Never installed them.
Old May 9, 2004 | 11:32 AM
MisterMissile
Cruising
Hey ZratedC5; thanks for the input; I got on the site and along with the wheel protectors also ordered sill and mirror protectors; I didn't really like the looks of the mud guards, but was concerned about "road rash" on the fenders. Looks like they are easy to use, won't detract from the look of the vehicle, and will do the job: Thanks again :yesnod:
Old May 9, 2004 | 11:46 AM
User 81424's Avatar
User 81424
Yes, the 3M is the way to go, BUT it also depends on where you live, if I was to move back to where I lived in Germany I would use real mud flaps on the front, even 3M couldn't stand the abuse.
Old May 9, 2004 | 05:43 PM
Shylor's Avatar
Shylor
Default Re: Mud Guards (CPT Z06)
I think those clear plastic films can't protect your panels as good as flaps. I've seen them on cars that didn't look to bad and you hardly knew they were there.
[Modified by Shylor, 4:53 PM 5/9/2004]
Old May 9, 2004 | 05:48 PM
User 81424's Avatar
User 81424
Default Re: Mud Guards (Shylor)
I think those clear plastic films can't protect your panels as good as flaps. I've seem on cars that didn't look to bad and you hardly knew they were there.
No, I lived in gravel central, you see that white spot right behind my front wheel? That's freakin primer!!!!!!
Old May 9, 2004 | 08:32 PM
Sandy S's Avatar
Sandy S
Mine looks the same way. I wish they could have don't something better there. My '92 with 130000 miles has less damage than my 03 Z06.
I guards on the 92 about a year and they work fine. The 03 requires drilling so I didn't put them on it.
[Modified by Sandy S, 8:33 PM 5/9/2004]
Old May 9, 2004 | 08:54 PM
fast4vette's Avatar
fast4vette
Default Re: Mud Guards (Zeppelin)
:iagree:
just drive the car and have fun.
it is not like you spent $200k on the bad boy.
the tires are wide and stick out. that is just the way it is.
just wait until your windshield pits and your nose gets a few dings.
you can put on mud flaps and look like a tard or just have fun.
heck, most of us spent more for our high end SUV's than the vette.
it's all good.
:cheers:
Old May 9, 2004 | 09:08 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Mud Guards (fast4vette)
I had some experience with mud flaps on my big ole' pick me up truck. :cheers:
To Mud Guards
Old May 10, 2004 | 01:19 PM
rwd's Avatar
rwd
The cheap, flat ABS ones are basically the same color as the tire and not particularly noticeable. The fronts use the existing screws and although the rears are supposed to require drilling, they can be held on with the single screw that is there from the factory.
Old May 10, 2004 | 01:20 PM
rwd's Avatar
rwd
Default Re: Mud Guards (rwd)
They can also be installed and/or removed in a couple of minutes.
Old May 10, 2004 | 06:54 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I am using the Altec molded and painted stone guards. The fit is quite good with a little sanding. You just have to take your time when you install them and make sure they fit perfectly before doing any drilling.
I don't have any paint chips behind the wheels.
Around the rear brake ducts; now that's a different story. That is the area we really need something for protection.
