[Z06] LS6 v LT5 question
The LT5, however, is clearly superior to the LS6 motor. Fewer cubes, more horse, better idle. Almost like an exotic car motor...
I think the LS6 is both easier and cheaper to mod, while the LT5 is more refined and has the "googaw" factor. Also much rarer. No ZR-1s at the Car show last night.
Lotus often is classified as an exotic...
Now the base Corvette engine makes 400 HP (LS2), you gotta love evolution.
Hello! 2005 calling.
As is, we've had to wait a least over a decade to see those levels again from the "in house" GM stuff.
But GM couln't get over the fact of Americas favorite sports car having a motor that was designed over seas.
There's more to the cost than just the motor price. Because the LT5 is much wider and somewhat heavier than an LS6, that would have meant a different design for the Z06, and it would need more Hp for the same performance numbers (to make up for the greater weight) AND the LT5, from everything I've read, doesn't have BSFC numbers as good as the LS1/6 -- IOW, not as fuel efficient.
Had the LT5 been further developed and used we would have seen 500+ hp levels in the C5. 475hp OBD2 ready LT5s were scheduled and a few produced for the 1995 Corvette. But GM couln't get over the fact of Americas favorite sports car having a motor that was designed over seas.
As for the LS6 making more torque, what are the numbers on a LS6 385/405 hp and ?? torque? Im not sure. I checked the GM site and couldn't find anything. Also what is the fuel milage on the LS6? Not what the EPA says, but what owners have seen on the road.
Who cares how many camshafts is has. Nobody claims Ferrari and their 4 cam design is inferior? Just becuase it's ten years old, means it's worthless? The Z06 has 7 more to go then. I should hope it's installed in a better platform, otherwise that would mean GM isn't advancing their technology.Hello! 2005 calling.
Hello, 1986 calling, GM/Lotus was getting that power. Thank you for waking up GM and finally getting around to it 15 years later
[Modified by Jeffvette, 1:18 PM 6/13/2004]
65mph for appx 1hr, 32 mpg
80-85mph long haul - san jose to anaheim, 27mpg
not bad for a 14 year old car.
Wow, somebody who is trying to sound intelligent. If GM decided to use the LT5 in the C5 and wanted to use it in all the models, let's just say 30,000 first year and use 30,000 across the board until 2004. Wouldn't you think it would cost less to manufacture 270,000 plus the warranty motors, than compared to say 6,939 plus warranty motors.
Also, let me go pop the hood on my Silverado. Has an ugly looking engine as well.
[Modified by Jeffvette, 1:30 PM 6/13/2004]
I can't find the article, but Dave Hill essentially said the reason for a pushrod V8 for the C5 was size and cost. Think of it this way... you're designing the C5. You already have a 400 Hp motor that's been designed and had a production run, yet you design another motor. Smells like a bean-counter issue to me.
The LS2 will be rated at 400 Hp. The LS6 is rated at 405 Hp. The LS2 will be able to accelerate a vehicle more quickly down the 1/4 mile. Why? Power under the curve. The LS6 on has a 5 Hp advantage at about 6300 rpm and up. At every rpm point under that peak, the LS2 has a torque advantage. More power under the curve will generally beat a slightly greater peak Hp advantage.Just look at the price differential between the base C4 and the ZR1 and the base C5 and Z06. The price difference between a base C5 and a Z06 is roughly $10K. Wasn't the price difference between a base C4 and a ZR1 more like $20K? I know the Z06 also added better suspension; was the same true of the ZR1?
As I've also mentioned, Dave Hill said that they chose a pushrod motor design because of space and cost considerations. Even after the LT5 had already been designed AND produced, the bean counters at GM determined it would be cheaper to design and build a new pushrod motor than to use the LT5.
Gas milage on my Z06: 21 mph city, highway mix. Pure highway, 32.5 mpg at 70 mph cruise, 30 minute trip. Will be going to Las Vegas in a month, so may have better long trip gas milage numbers.
[Modified by nuke61, 11:17 PM 6/13/2004]
ZR-1. Well, let's buy the two doors, the whole rear clip and lower valance. The solar glass and a completely different offset rear rim. Now, I've got the look...... but what do I do when I pop the hood and show people my L98/LT1/LT4
As far as price. My ZR-1 stickered at 59,xxx. A 2001 Z06 stickered at 48,xxx and change. Not that much of a diffence. But factor in you see a Z06 on every corner
ZR-1
90 3,049
91 2,044
92 502
93 448
94 448
95 448
Total of 6,939
Z06
01 5,773
02 8,297
03 8,635
04 (I imagine it will be another 8,000)
Total of 30,705
When will a Z06 do this?
NEW INTERNATIONAL RECORDS
100 Miles @ 175.600 MPH
500 Miles @ 175.503 MPH
1000 Miles @ 174.428 MPH
5000 KM @ 175.710 MPH
5000 Miles @ 173.791 MPH
12 Hours Endurance @ 175.523 MPH
24 Hours Endurance @ 175.885 MPH for 4,221.256 Miles
WORLD RECORDS - IRRESPECTIVE of CATEGORY or CLASS
4,221.256 Miles @ 175.885 MPH
Or is GM, to afraid of ring failure and excessive oil consumption?
With that attitude, you should be overjoyed that GM isn't going to use the LT5. It makes your car all that much more rare. I actually like the idea that if I pop the motor in my Z06, I can just go out and get another one. To each his own.
Uh, wonderful, but that wasn't the question. I asked what the price difference was between a base C4 and a ZR1. If you don't know the answer, it's O.K. to simply say "I don't know."
Oh brother... now you're starting to sound like some Ferrari and Lamborghini owners
If you are going to start talking common sense forget about it with ZR1 owners....Lord knows I've tried.......I like to keep it simple and powerful!!!!
http://www.musclecarclub.com/musclec...istory-4.shtml
It turns out my earlier guess of a $20K price difference between the base C4 and ZR1 was low. That nearly $30K price difference helped pay for the then state-of-the-art motor.
Bean counters get involved in all sorts of decisions that might initially surprise you. I just read in Automobile Magazine that Honda will likely NOT produce a successor to the NSX. Why? It's easier to get financial approval to make a followup to the Civic for the masses than a niche car with a niche motor.
Doh... I just checked Jeffvettes profile and he's an accountant... maybe that's why he has a chip on his shoulder
edit: also, what is the largest that you can bore a LS1/6 out. I remember reading that a 383 or was it a 39x was the largest you could go. I can't remember.
[Modified by 90 Corvette ZR-1, 9:56 PM 6/13/2004]
