CLB is not the answer
Don't know what caused the problems but they all went away after the CLB was removed.
From the responses on this forum and others I would say there appears to be a problem with using it in all applications.
Called my trusty Corvette Mechanic at Titus-Will Chevrolet (Olympia, WA)
He checked the recall list (nothing for mine he said)
I asked if I should install a CLB.
His response was, not a bad idea, might help, couldn't hurt. I asked if it would instigate any problems. He said no.
He installed it in about 15 minutes and said he was very impressed with the device.
This was for a 2002 6MT Coupe.....about two weeks ago....
Hmmmmm. Does anyone know... are all CLBs created equal (i.e., designed and manufacturered by the same company regardless of where purchased)? Or are they designed or made by different companies? Are there different versions or revisions? May I ask those folks with 100% successful installs in '97s and '98's... no codes or other nonsense whatsoever... when and where did you buy your CLB???
Monk
It can be done 2 different ways, 1 is with a scan tool and it's a fast re-learn.
The 2nd way is lenghty, about 35 min. either way should work but with a CLB in place in my car neither worked.
I would like to point out another thing, if the CLB was the answer, don't you think GM would be the first to install it in every A4 Corvette that has the problem?
Of course they would, it's one heck of a lot cheaper and simpler then removing the lock plate out of the steering column.
And then installing a harness with hardware to keep the lock motor connected in the system.
IMHO the CLB was designed around 1 particular vehicle's software and then in typical aftermarket fashion was marketed as 1 size fits all.
I know my car was throwing codes that had nothing to do with the column lock with it installed and with it removed they all stopped.
We should remember these cars have more computing power then the first Apollo mission that landed on the moon.
Or am I missing something here?
Monk
Monk
Not all problems throw codes.
C4C5 a well respected mechanic does not reccommend the installation
of the CLB as it does not maintain proper voltages to the BCM thus possibly throwhttp://corvettemechanic.com/board/index.php?act=ST&f=3&t=684&ing codes.
For what it's worth, I'm on my 2nd CLB from JMX and I still frequently get the "Pull Key" message when the car interior gets hot. I cycle the key and it goes away (never had the message 2 times in a row) but it gives me pause and I'd love to have a recall that really works.
88952427 Plate (Replaces column lock plate)
88952429 Harness (Plugs into existing harness between BCM and lock drive motor).
These P/N's are good for 97-98 for sure, for other models I would suspect only the harness might change.
For those of you that have a CLB and are happy with it great
But I sure hope you never have to do a key re-learn cause it won't work, at least mine didn't!
And who knows what other issues may arise from it.
I also plan on installing the kit myself.
I thought the "kit" included the harness and the plate?
Give us some info on where you bought it, how much it cost, what's involved in the installation and how long it took you.
