I figure that if manufacturers like Calloway want to give bhp (crank) numbers, then I can say that I have gained 14.5 bhp (minus one or two for the Borla Stinger cat-backs) for an intake system cost of $199. Compare that to the price of the Calloway and I think you'll agree that the Stinger-R gives you much more for the money. Add tuning and you've got at least 25 bhp.
I do suspect that in order to generate the 17 bhp number, Calloway probably blasted a 200 MPH fan at the front of the car. I'll bet that if I did the same to my car, my bhp woulda jumped to 17 or 18 easily, since I too, have a cold air system. In other words, take what you read with a grain of salt - the K&N FIPK is advertised to increase RWHP by 17.7. It is possible, but only if the airflow conditions are real-world, whereas most dyno shops do NOT have the capability to simulate 100 mph+ air velocities.
From my experience in porting heads, the highest flow numbers do not always produce the biggest gains in performance.
you are correct in a sense... Someone could take a rectangle, octagon, whatever, and it might outflow another ported head design however, the power often comes with the shape of the combustion chamber, the port shapes them selves, and other variables -
What I saw with the Callaway airbox, were features other "kits" did not have. It makes sense to move the mass air sensor for a truer reading right before the throttle body and also, that makes it so that restriction is not dictating the design of the air duct (the bridge over the radiator).
These design features, coupled with the smooth bellow transitioning into the engine make the (flow) numbers, plain & simple
CallAway tested all "popular" brands with the same methods - Bottom line, Callaway's set-up outflowed them.
I'm stuck inbetween the Vararam vs. Halltech Stinger
Vararam:
-Proven HP gain, and lower 1/4 and 0-60 times
-Colder, denser air
-Difficult to Install
-Somewhat questionable construction and fit quality
-$350
Halltech Stinger:
-Proven HP gain
-Warmer air, but still huge improvement
-Easy to install
-Nice fit quality
-$199
I'll figure out which one I want one of these days
I couldn't decide either and had a similar pros/cons list. Finally I decided I couldn't accept an inferior quality product at a higher premium and ordered the Stinger. I felt better immediately, knowing I had saved myself (or the dude I would've paid :p: ) the headache of a 3 to 4 hour install AND still having to jerry-rig it with extra clamps or silicon. I don't plan on any dyno runs or whatever because it's not that big a deal, & I'm no bracket racer. Just wanna enjoy my daily driver (LOVE the B&B bullets & GS-D3's) and not have some cobbled together looking part sticking out on cruise night or *gasp* in front of some other Vette owners! The horror!
For me the decision was easy. Anything that involves CUTTING A LARGE HOLE in my car is out of the question. The vararam was a bit tricky to install but once it's in and you hit the gas pedal you will forget all about the time or expense and you will be very happy with your purchase.
