[Z06] Tune up time?
Old Jul 28, 2004 | 03:39 AM
02 batmobile's Avatar
02 batmobile
Default Tune up time?
I've got 24K on the odometer now. She stills runs good but I'm thinking its time. Any recommendations? Those who have done your own tune up, wanna share the shortcuts? What parts did you replace?
Old Jul 28, 2004 | 05:13 AM
Shylor's Avatar
Shylor
You think it's time or your owners manual says it's time? I'd follow the owners manual.
Old Jul 30, 2004 | 08:33 AM
02 batmobile
What is the recommended interval for a tune up?
Old Jul 30, 2004 | 08:46 AM
User 81424's Avatar
User 81424
The DIC will tell you when it's time to change the oil, and the plugs and wires are at 100K, and I think the anti-freeze is 5 years, and tranny and rear end fluids are at long time and mileage intervals also, of course these intervals need to be reduced if you race. You might want to look at your air filter too.
It's not the 60s any more, no more point gaps to adjust
Old Jul 30, 2004 | 09:00 AM
fast4vette's Avatar
fast4vette
for the first 100,000 miles on a z06, all you need to change is the oil when indicated by the dic and air cleaner filter when dirty upon inspection.
this is what is recommended in your owners manual. the chevy small block has been around since 1955 so hopefully their recommended maintenance is adequate.
but you are free to do whatever makes you happy. if you like spending money, just buy a new 04 as there are some great deals to be had and you'll be good for another 24K miles.
Old Jul 30, 2004 | 10:16 AM
Goody's Avatar
Goody
Tune-up??? What is that???
Hmm lets see.....
Plugs good for 100,000 miles.
Wires good about the same unless damaged.
No distributor to adjust or timing marks to check.
No valves to adjust.
No carb to adjust.
Timing chain good till who knows when....
Aircleaner could use a swap I would think. So that must be a tuneup now because nothing else is needed.
Old Jul 30, 2004 | 10:47 AM
Painrace's Avatar
Painrace
I would not let the coolant go five years. There have been problems with other cars.
Old Jul 30, 2004 | 12:44 PM
Shylor's Avatar
Shylor
Nor do plugs really last to 100k miles.
Old Aug 1, 2004 | 07:26 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Which plugs are better to use? the NGK TR55 or the new AC Delco?
Old Aug 1, 2004 | 07:40 PM
slong's Avatar
slong
NGK TR55 IX Iridiums are great plugs!
Old Aug 1, 2004 | 09:33 PM
Cruncher's Avatar
Cruncher
Can you please explain why the NGK TR55 IX Iridiums are so great? I don't have a clue when it comes to plugs. Thanks!
Old Aug 1, 2004 | 09:42 PM
erikszr1's Avatar
erikszr1
How about a Motor Vac?---------its a internal engine & fuel system service/cleaning. Anybody have a opinion on this for a zo6? I own an auto repair shop ang get great results on other cars usually with higher miles.
Old Aug 1, 2004 | 11:26 PM
bmacZO6's Avatar
bmacZO6
Change the plugs, the antifreeze, brake fluid and the air filter.
Anyone that thinks the plugs will last 100k and they will still be able to get them out is dreaming or taking an unnecessary risk. The guidelines in the owner's manual have a lot to do with advertising and little to do with reality. They are in the business of selling cars, not making sure yours lasts forever. Plugs should be changed at least every 30K and brake fluid should be changed at least every 2 years. Moisture in brake fluid is normal and can cause big problems if is not replaced. All of these things can easily be done for less than 100 bucks. Isn't your 50K car worth a 100 bucks every couple of years? I know mine is.
Old Aug 2, 2004 | 12:12 AM
Shylor's Avatar
Shylor
Originally Posted by bmacZO6
Plugs should be changed at least every 30K.
I agree with everything you said except this. The 30k mile plug change was before the newer plugs were designed. While I agree they won't last 100k miles but, changing them at 30k miles is to early. I think 70 to 80k miles is more like it.
Old Aug 2, 2004 | 12:28 PM
mforman42's Avatar
mforman42
I humbly disagree. The 100K miles on the plugs has to be guaranteed in states with 100K emission warranties, including California. So, this is not for advertising purposes only. GM has to meet emission requirements for 100K with only recommended maintenance. Still, if you feel it is better to change them, do so. Just don't 'rag' on GM for something they didn't do.
Old Aug 3, 2004 | 10:58 PM
bmacZO6's Avatar
bmacZO6
I agree that 30k for plugs is a early. The more important consideration is that they be loosened and retightened. In my case as long as I am doing that I just replace them, but that is personal preference. The worst case scenario is a plug that is frozen in the block because it has been in there for 10 years. The plug wires will also be very difficult to remove without damage if you wait too long.
Old Aug 3, 2004 | 11:18 PM
Thud's Avatar
Thud
My '95 Ford Ranger has 110k on the clock, still with the original plugs and wires. It runs great.
I'd like to think the technology in a 2002 Z06 has been improved even more.
To Tune up time?
Old Aug 3, 2004 | 11:39 PM
Sho-nuff's Avatar
Sho-nuff
From: When I say who is the masta you gotsta say Shonuff
The Delco plugs lose their pucks too early.
Old Aug 3, 2004 | 11:48 PM
Sho-nuff's Avatar
Sho-nuff
Old Aug 5, 2004 | 08:58 AM
Anthony Cleveland's Avatar
Anthony Cleveland
I do not blame you for a doing a tune up. My last C5 was a 2000 hard top in which I changed out the plugs and wires at around 20k. The stock plugs in these things are really not performance plugs. They are great for a lot of miles and that's about it. Get you a good set of wires and some good non platinum plugs.
