Need some help please....
Old Aug 6, 2004 | 09:16 PM
Medivh's Avatar
Medivh
Default Need some help please....
was out looking at the airbox, was gonna modify it till i get a better intake. This d@mn thing came off and won't go back on. Cut up my hand pretty bad, and i can't see where to attach it to in the front. i know where the handle goes... obviously. and the GM service manual doesn't say s**t. Anyone know??? Here's a pic of the piece.
Cause 1 of 2 things are gonna happen...
1. Someone is nice enough to help me out...
-=OR=-
2. Bust out the Remington 870 and the car is toast!!
Last edited by Grumpy; Aug 6, 2004 at 09:56 PM. Reason: attempt to circumvent the fourm censor
Old Aug 6, 2004 | 09:33 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
They can be a pain in the ****...feel in front, and you will feel where they latch on, maybe if someone else can help latch them closed while holding it in place...I still suggest changing it in the long run
Old Aug 6, 2004 | 09:38 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
they do latch to the lower front of the rear 1/2 of the housing, if you can't get it to re-attach just take the complete unit off (at the throttle body) only takes a few minutes to remove entire unit, then you can see how it attaches. Good luck
Old Aug 7, 2004 | 12:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The air box unit attaches to the front with two rubber gromets! Attaching the metal retainer bands with the air box removed is a snap! Once the bands are attached, the lid is securely in-place and the two handles are snapped back down; go ahead and clip the entire (ASSEMBLED) air box back on the two rubber gromets!
Once I found out how this worked I can change my filter in 2 minutes!
BC
Old Aug 7, 2004 | 01:28 AM
Tim2K4Vert's Avatar
Tim2K4Vert
Yep, it's probably easier to just remove the whole thing, put it together and then put it back in.
Old Aug 7, 2004 | 08:23 PM
Medivh's Avatar
Medivh
Ok, i got the friggen car put back together.... after many cuts, some serious, 6 dead mesquitoes, and 4 times as many bites.
..... and no Corvette's were injuried during this process.
Anywayz... thought i'd share some information incase anyone needs it now or later. There are 2 bolts holding the top piece of the airbox to the front of the car. You can see them (one is missing in the pic.) on the bottom right and left corners. (the key FOB is just showing the size of the intake to the filter. there are some other small openings on the sides, but i didn't get a pic of that. Besides, its stock.... stock sux.
They are a torx 30 head. extremely hard to get out if it hasn't been removed since the factory. I recommend just pulling the box out. The screws will pull through the little gromets and nothing will get hurt.... except maybe you. If you are trying to put the air box on, what i found works EXTREMELY easy is, to put the bolts for the top box back in the posts, then push the box on over the heads of the bolts. Cause you ain't getting a screwdriver down in that box to screw them in. Done asked the doctor, can't be done!!
Old Aug 7, 2004 | 08:27 PM
PaulaH's Avatar
0PaulaH
Former Vendor
I will make you a deal! If you install my Euro's, I will fix your air box! I can do that!!!
Old Aug 7, 2004 | 11:31 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I know your frustration!! To bad the manual doesn't explain a simple procedure better than "Take out the airbox". Until you've done it it hard to comprehend how it's done just by looking at it.
Old Aug 7, 2004 | 11:34 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VII Veteran
Originally Posted by Medivh
Cut up my hand pretty bad,...
Hopefully you did need stitches
To Need some help please....
