Column lock Plate?
Old Aug 7, 2004 | 06:21 PM
cuspid's Avatar
cuspid
Default Column lock Plate?
Why is no one just removing the lock plate as an alternative to the bypass? Is it more involved?
Old Aug 7, 2004 | 07:26 PM
johninar's Avatar
johninar
Nope. If you have the MN6 just order an A4 plate. (late model)
Old Aug 7, 2004 | 07:45 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Old Aug 7, 2004 | 07:52 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Even though there would be nothing for the column lock pin to engage into,the vehicle would cutout if the pin failed to retract when starting.This would happen because the position of the pin is monitored by the BCM
Old Aug 7, 2004 | 08:52 PM
Old One's Avatar
Old One
Can somebody please post a sketch of the bleeping thing? I can't visualize how it works.
Tnx
Old Aug 8, 2004 | 03:36 PM
cuspid's Avatar
cuspid
Me too
Old Aug 8, 2004 | 03:52 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Old Aug 8, 2004 | 03:56 PM
JoesC5's Avatar
JoesC5
I had the column lock recall performed on my 98 A4 last week. The tech told me the harness kit he installed consisted of a relay to keep the computer from throwing codes as well as the lock plate. When I insert or remove the key I don't hear the motor in the column lock so I'm assuming the column lock ***'y is unplugged with the relay in it's place in addition to the lockplate. It sure is a relief to know that I can't have the steering column lockup on me.
Old Aug 8, 2004 | 04:43 PM
DocToss's Avatar
DocToss
I thought the recall for the A4 2000 just removed the lock plate?
Old Aug 8, 2004 | 05:22 PM
johninar's Avatar
johninar
I should have stated above, that I would still do the CLB. CLB+ A4 plate I feel is the best solution.
Old Aug 8, 2004 | 08:54 PM
dilockwood's Avatar
dilockwood
8th Gear
I installed the CLB last year on my 97 A4. I then recieved the recall three or four months ago. Took it in they said they were going to remove the locking plate. When I got it back, CLB was in glove box and the locking motor runs again when I turn car off. Does this indicate fuel will be shut off if the locking motor malfunctions? Maybe I need CLB reinstalled??
Old Aug 9, 2004 | 01:37 AM
SAVETTE's Avatar
SAVETTE
I was going to take my 97 A4 in for lock plate removal on the recall notice I received. I do not have the CBL installed. I am concerned as I have 3:42 gear ratio and 2400 converter, so I am wondering if I will get Error codes at some point, requiring pcm programming.
Old Aug 9, 2004 | 07:56 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Not to worry The "fix" on an automatic does not include reprogramming. ONLY the 6 speed gets a reprogram. Go ahead and get it done.
P.S. I had the fix done to my '98 A4 over a year ago. My car has a 3.42 rear gear and I have had no codes and the car runs and shifts great.
Old Aug 9, 2004 | 08:40 AM
johninar's Avatar
johninar
I would. If the Column lock malfunctions and stays in "locked" position, I believe the computer will still shut off the fuel. I would install the CLB. You already have it, so 15 minutes and you're fixed forever.
Old Aug 9, 2004 | 09:17 PM
dilockwood's Avatar
dilockwood
8th Gear
I agree, just been draging my feet.
Old Aug 12, 2004 | 12:05 PM
SAVETTE's Avatar
SAVETTE
Thanks For The Quick Response.
I Am Taking My Vette In Today.
Old Aug 12, 2004 | 01:52 PM
TorchRedRaider's Avatar
TorchRedRaider
No.
Get the A4 harness, lock plate is added insurance but not necessary. Aftermarket CLB's do not use a lockplate.
See my write up on using the A4 kit on my MN6 http://forums.corvetteforum.com/showthread.php?t=881814
To Column lock Plate?
