Help Codes !!!!!!!
Old Aug 13, 2004 | 06:14 PM
UpToVT's Avatar
UpToVT
Default Help Codes !!!!!!!
Just got back from the dealership where the replaced 2 new valves, by the time I got home I have 20 codes gone wrong. I have listed them, can any one help me out by telling me what these codes mean. And is the car driveable??? Doesnt sound bad, nor is the check engine light blinking. I appreciate any help..... Thanks UpToVT
10 PCM 1 CODE - PO300HC
58-SDM 3 CODES - U1000H, U1016H, U 1096H
AO-LDCM 6 CODES - B2282H, B 2284H, U 1255H, U 1064H, U 1016H, U1096H,
A1 RDCM 6 CODES- SAME AS AO LDCM-
BO RFA 4 CODES - U1255H, U1096H, U1064H, U1016H
Thanks for the help......
Old Aug 13, 2004 | 06:21 PM
VetteSiNz's Avatar
VetteSiNz
check this out: http://www.corvettedoctor.com/2003_Codes.htm
Old Aug 13, 2004 | 06:26 PM
UpToVT's Avatar
UpToVT
Neither transmitter is working either. I guess back to the shop it goes.... Third time in 6 weeks, and off those 6 weeks, 13 days of not driving my vette. Kinda getting discouraged.....
Old Aug 13, 2004 | 06:32 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Just so you are aware, all the "H" codes are History codes and are NOT new. They've been in there for a while.
The PCM 0300 is telling you the system detected a cylinder misfire.
I'd clear all codes and see how she reacts after that!!!
Old Aug 13, 2004 | 06:36 PM
WWK888's Avatar
WWK888
It appears that all but the first code (engine misfire detected) is a history code. I would try to clear all the codes and see if they reappear.
As far as your key fobs, try doing the relearn procedure before going back to the dealer. Maybe they just lost their memory when the battery was disonnected during the repair.
edit* Glenn you beat me by 4 minutes
Old Aug 13, 2004 | 08:07 PM
UpToVT's Avatar
UpToVT
Clear codes ???
Do I need a programmer for that..... Im guessing I do.....
How long would it take to relearn for the transmitter ??
Could they do it as I wait....
Thanks for the help everyone
Old Aug 13, 2004 | 08:12 PM
WWK888's Avatar
WWK888
Go to the below link and it will explain how to read and reset your codes. If you have a manual you can look up the relearn procedure for your key fobs. If I recall off hand you press the both the lock and unlock buttons at the same time, then follow the menu on the DIC.
http://www.stengel.net/diccodes.htm
Old Aug 13, 2004 | 08:49 PM
UpToVT's Avatar
UpToVT
Ill have to go to the dealership to get my transmitter going. But I wrote down all the codes, and cleared all of them. I will see what the dealership says....
Thanks for your help
BTW. I just got stung.... My quad tip stingers which go installed today sound awesome and ny dad believes Ill attract more cops than a toilet seat gets *** in a girls dormitory.
To Help Codes !!!!!!!
