Decarb Tests/Results
If not, I would be willing to do the test, since I will soon have both products. Unfortunately, I don't think I have anything laying around with carbon on it. If I did, I would've already just put the part in the car along with the other carboned pieces! (That's a joke)
The only thing I have is an old piece of exhaust from near the tailpipe of an old rice car I have that broke off, but I'm not so sure exhaust pieces would even attract the type of carbon on them that we get on our pistons.
The reason I'm asking is because I'd like to know how effective a chemical like Top End Cleaner or Sea Foam really is. I mean, all results on this forum have been SOTP, but does that mean the stuff really gets deep enough into the carbon on pistons to actually break the carbon off? Or is it that people only feel a DIFFERENCE, and that the carbon really isn't removed, but instead only taken down enough to alleviate a ping or lower compression enough that you might notice a difference?
Of course, if I had a boroscope, or some kind of attachment I could put on a video camera or something, that would be even better, since I would be able to see the actual results of a decarb treatment on a real engine.
So, if anyone has experience in what I'm proposing, please chime in, as I, among many others, I'm sure, would be most interested in hearing from someone who's actually SEEN the effects (or lack thereof). If anyone wants to send me an old carboned-up piston, or several would be even better, I would be more than happy to test and post the results. I would test each product in hourly increments up until the products either work or fail. This way we'd also get to see how long the stuff really has to sit concentrated on a spot to even work.
I'd also test different levels of concentration, since many of us do the intake method, which I think (hopefully, erroneously) probably does not concentrate as much of the liquid on the pistons as the direct-into-the spark-plug-holes method does. Speaking of which, is directly dosing the cylinders necessarily better than the dosing via the intake method?
Thank you for taking the time to read this.
I design miniature medical hi-res steerable fiberscope systems and catheters which are used to snake up into the spine for diagnostics and drug-delivery and have been thinking of trying one of our setups to look into otherwise inaccessible areas of a closed engine. I should be able to get to areas you can only see normally by pulling the motor apart. The combustion chamber would be pretty easy to peer into.
EDIT: Whoops, just re-read your post. I probably don't have more than a $100K limit on my card to even have you approve. I originally didn't realize the extent of the product you're talking about. I mean, anything made for the medical industry is at least a quarter mill, right?
I do have access to a boroscope, and the one thing I can tell you is I had heavy carbon deposits within 1,000 miles on my 02 when I got it.
If so, what were the results... and, which method did you use to dose? Pour into the intake with the engine running, or did you pour into the spark plug holes?
If not, are you considering doing it?
In either case, thanks for the feedback.
My first car that I got to consider my own... '68 Buick Skylark bought in '92 with only 32000 original miles on it. The engine was all carboned up because the 91 year old driver only took the car down the street for the grocery store and church.
When my dad first bought the car, he would tell me to go out on the highway and hit it... well, choke, choke, plume of black smoke, then ride first gear in the 350 w/ powerglide up to 70MPH before I got scared and backed off... but I digress
We poured a whole can of Seafoam into the carb one afternoon and smoked out the neighbor (sorry!) A few days after that I really didn't notice any hesitation or black smoke under heavy acceleration. Did it really remove the carbon? Not sure, but it definately seemed to help.
Do you know if your service techs use the cleaner via the intake while the engine's running, or do they go the route of removing plugs and pouring through the spark plug holes?
I would think that if a service facility charges for the work and does it through the intake, then that must be working WELL, right? Otherwise, they'd have switched to the through-the-plugs-holes method. I'm trying to determine if the dosing through the intake really will cover the pistons with enough product to do the job. While the through-the-plugs-holes method sounds more effective, through the intake is cleaner, easier and helps clean the rest of the intake system, and not just the cylinders. Unless, you really have to do both.
Thanks for the input.
Yes, it is rather expensive stuff. I can borrow it for a day and scope my car.When I did heads/cam on my car, the motor only had 2900 miles on it. The piston tops were coated with a thick layer of carbon deposit that required us to scrape them with a razor blade. If it's that bad after just 3K miles, imagine what a 30K motor is like. I've never heard of the GM top end cleaner hurting an engine and the results reported here portray it as at least innocuous, if not effective.
Fuel Power
Seems to me that the GM Top End Cleaner worked for you then, but since you did nothing to prevent the oil from getting back into the intake after decarbing it, you saw the condition return. Another member mentioned recently that at only 1000 miles (or something low like that) on a new car, he used a scope to look in the cylinders and was surprised to see how much carbon there was, which sounds about right if your condition has returned after the 800 miles.
I've done the DIY catch-can recently and see much more oil than I expected. If I were you, I would do a catch-can, then decarb again. If the catch-can stops the oil, you will probably be in good shape. At least, that's what I think.
As far as start-up tick is concerned I think you've got that piston slap some motors are susceptible to. You might want to check out some info on that. From what I understand, the slap only happens for a short period after start up, then goes away. GM has re-ringed engines for that on a case by case basis.
