Halltech Stinger R
Old Sep 17, 2004 | 02:23 AM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
Default Halltech Stinger R
Any downfalls for installing one of these units???
Should i expect any problems when the dealer is servicing the car???
Will the Halltech violate any warranty issues????
Old Sep 17, 2004 | 04:11 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
It's probably going to rub against your hood blanket, don't know about warranty, think there's been many posts here about that.
Old Sep 17, 2004 | 04:51 AM
NSTG8R's Avatar
NSTG8R
Doesn't the old saying go, "if you have to ask then don't do it"
Old Sep 17, 2004 | 11:21 AM
Dave68's Avatar
Dave68
Not at all. In fact, you'll gain 10+ RWHP in 20 minutes (check my sig).
I've taken mine in twice with this and my cold air mod and have had NO problems whatsoever.
...not unless you spray tons of oil on it. Otherwise, you should have no problems in that regard.
This is truly the best bang-for-buck mod you can do in so little time. HIGHLY recommended!
Old Sep 17, 2004 | 05:27 PM
F.J.B.'s Avatar
F.J.B.
Thanks Dave for the info.....
Neablas....its IF YOU HAVE YOU ASK YOU CANT AFFORD IT>>>.but thanks for you help.....
Old Sep 17, 2004 | 05:32 PM
P51tj's Avatar
P51tj
A little hood liner rub, but as Dave said so eliquintly..."best bang for the buck! By the way I'm luvin mine!
Old Sep 17, 2004 | 05:40 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Great mod! Now you will only have to consider a hood seal if you drive in heavy rain.
Old Sep 17, 2004 | 06:00 PM
F.J.B.'s Avatar
F.J.B.
That would be the High Performance Hood Seal......Already have it...was second mod only to the HP MATS>>>...talk about SOTP .........................
Old Sep 17, 2004 | 08:32 PM
01VETTECOP's Avatar
01VETTECOP
i wanna get one too. I'm thinking about ordering this week. Need more HP
Old Sep 17, 2004 | 11:02 PM
JeffLexie's Avatar
JeffLexie
I just installed my Stinger this evening and couldn't be more happier. Installation was fairly simple, took me about an hour. As soon as I started it I could tell something was different, you could here the air going into the intake a little. I took it for a test ride and my first thought was, "Yeah baby, yeah!" The response time and get up and go when I got on the gas was definitely improved. I only drove about 3 miles total and didn't see any codes. I'm assuming they would show up on the DIC if there was one. My big test will be my trip to Key West next week. Long story short, I highly recommend it! The hood seal goes on tomorrow morning. Wrong thread, but I installed the window valet as well and I highly recommend that product too, especially if you have a vert.
Old Sep 17, 2004 | 11:18 PM
Medivh's Avatar
Medivh
Just installed mine too. Installation instructions were lacking, but i know enough about intake so i figured it out on my own. Installed in like 15 - 20 minutes. on the test ride, didn't see a large increase but she sure is louder! Will have to let the PCM adjust to this bad boy and see how it reacts.
Old Sep 17, 2004 | 11:31 PM
Dave68's Avatar
Dave68
My installation procedures, complete with pictures are available for download on Halltech's website. I'm guessing you somehow got ahold of Jim's "quick-guide" instead.
Old Sep 18, 2004 | 07:45 AM
Medivh's Avatar
Medivh
Yes, that is what i got. It came in the box. I have the link for your which is alot better.
Old Sep 18, 2004 | 09:42 AM
HHC5's Avatar
HHC5
I used the website instructions--very, very simple. It took about 45 minutes.....nice mod!!!!
Old Sep 21, 2004 | 12:20 AM
F.J.B.'s Avatar
F.J.B.
Still waiting on delivery of my Halltech. Also getting the Flush Tail Light Kit. Does anyone know what screwdriver I need to remove the stock tail lights on my 04?? Its not a simple flat or philips! Help Please!!!!!
Old Sep 21, 2004 | 12:40 AM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I'm liking mine
Old Sep 24, 2004 | 10:20 PM
F.J.B.'s Avatar
F.J.B.
Finally received my Halltech and Flush Tail light kit today!!! Oddly enough it was Fed Exed last nite!!!!!!(Go figure)........
Hall tech was tricky but did finally go in. Only about 45 minutes and one neighbors help. Not bad for someone with NO mechanical skills at all!!!!!
Is the Hissing sound normal around the filter element??? Its not coming from any of the connections....sounds like a sucking sound.....
Looks like all clamps are tight....is too tight possible????
Yes it rubs a little into the Hood Liner....but not enough to care...
Flush tail light kit was flimsy. Got easier as each light went in. So needless to say...the first one is the worst one. And if anyone is wondering....to answer my own question.....it required a #15 Torgue driver to remove the stock screws.
All in all nice package from CORVETTE GARAGE. Thanks for the GP on the Halltech.
To Halltech Stinger R
Old Sep 24, 2004 | 11:51 PM
Dave68's Avatar
Dave68
Is the Hissing sound normal around the filter element??? Yes, if you do not have a cat-back to drown out the noise. Some hissing is possible, but I can't hear any over my Borlas. Its not coming from any of the connections....sounds like a sucking sound.....
Looks like all clamps are tight....is too tight possible???? Absolutely. As a rule-of-thumb, tighten until neither component can be rotated. Overtightening may distort the tubular connection and allow leakage.
Enjoy!
Old Sep 25, 2004 | 12:10 AM
StevieB's Avatar
StevieB
I think the stinger is only half the equation. The cool air intake mod is the other half. Dave designed this ingenious modification that includes a scoop on the underside of the radiator shroud. Because of the C5 intake design, this scoop is positioned where it will grab air that is already being pushed up by the front spoiler. It’s in effect, the same as a hood scoop for a car that has the intake on the top of the engine. Dave made a 15 page ultra detailed set of instructions you can download off the Halltech site.
This is a picture of my Stinger with the cool air mod. You can see the screen that covers the hole where the cool air enters.
Old Sep 25, 2004 | 03:22 AM
F.J.B.'s Avatar
F.J.B.
Thanks Dave.,....so far so good.....just got back from a Midnight ride with the wife. Put about 100 miles on the car. NO error codes yet, and the car sounds good and drives great. Only issue I had on the ride was when the Kawasaki Ninja did a FLY BY on me as if I was parked. I was doing slightly(well) above the limit and he had to be going about 130. Great night out!!!!!!!!!!!!! My wife loves the car and CANT drive a stick shift and has no desire to!!!! She just makes faces when I talk about the MODS.
Stay safe out there and drive it like its stolen!!!!!!!!
