Winter Storage Tips
I'm glad you folks in the warm weather enjoy this fun we get to have in the frozen tundra.
What's up with the Amoco Ultimate gas problem? That is exactly what I was going to use with Stabil. My son used it last year with Stabil when he stored his Trans Am and I used it when I stored by 2002 Firebird. And, we just put his Trans Am away today with a fill of the Ultimate and the Stabil. Could you have just gotten a bad tank of gas? If there are problems with that gas, I certainly want to know about it now. I can't imagine the Amoco Ultimate is exactly the same everywhere in the Country. But, enlighten me if you know something I need to know.
Despite the fact that I have to put my new Vette into hibernation soon, you guys do crack me up.
Later. Dan
The fogging oil comes in a squirt can, readily available at just about any auto parts house, or for certain at any marine dealer. After the engine is up to operating temp, start squirting the fogging oil in the air intake for 20 to 30 seconds continuously. The engine would sort of sputter for a second, but the ECM (computer) would sense the change and adjust timing and fuel automatically. After about 30 seconds, shut the engine off, then you are done.
It WILL smoke (white smoke out the exhaust) when you first start it up, but that is normal and will only last a few seconds.
Not sure this would apply to car engines, but don't see why not. Any respected marine shop would say this is standard procedure!
Another factoid I learned was that condensation in the fuel tank is all but non-existant on non-metalic fuel tanks. With ABS plastics, just can't happen. That is not to say that water could not enter from another source, but good fuel and Sta-bil are mainstays for winterizing the Indmar Monsoon fuel injected 350 hp engines.
FWIW ~~~~~
FWIW ~~~~~
And are these boats equipped with O2 sensors and cats?
Maybe someone can chime in with some info on this.
Regards, Dan
Otherwise, the contaminants stay over storage.
I am not a mechanic, but this seems to be advice in all I've read. I do store my car over winter & always have fresh oil prior to storage.
My real opinion? It doesn't matter. It's not going to be the cause if your car dies. Drive it as long as you can in the fall. Get it out as early as you can in the spring. Drive it.
Scott
Regards,
Garibaldi
When springtime comes, just drive it gently at first since the gas in the tank will have lost some octane. Make sure to keep topping off the tank every 100 miles or so, and try not to go full throttle until you've freshened up the tank a few times. The battery tender idea is an excellent one.
That is great advice patman!
...... we'll leave the light on for ya
