Poser or not???
Old Oct 10, 2004 | 12:12 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
ET,
Let me start off by saying that your looks FREAKIN HOT... that looks sooooo good. Almost makes me want to buy a coupe.
Second, are your ducts the same set that was mentioned before? If they are, for being in the bodyshop business, I have to admit that I'm embarassed for not having the foresight to see how good they look when done. After years of putting on ground effects, spoilers, modifying fiberglass, I can usually look at something as see what others don't.
The side intake ductwork (fiberglass rockers) look great... like they belong.
Thanks for everyone's opinion, I'm still going to look into it, just not going to spend 800+ for that kit... may be forced to go factory.
Mark
Old Oct 10, 2004 | 03:14 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Do it! They look good on all body styles...and even better painted! I have mine protected by 3M film and you cannot see this stuff unless you are literally inches away.
Old Oct 10, 2004 | 05:36 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by MyBlueC5
ET,
Mark
My rear braake scoops, including the inner ducts outer scoops and template cost 299 dollars... .. I glassed them in myself,, and I've never done body work... these brake scoops as seen are from Breathless Performance Products. Although they are designed to fit ontop of the rocker like the Z06 style.. I molded them in... Body shop said it would take them about ten hours to mold in and paint etc.. it took me 20 hours.. but it was the first time I did body work but I do have gifted hands.. I wanted to try to do some body work myself and i figured If I screwed it up I would just pay someone to fix it..
The body shop wanted to hire me when they saw them...
Old Oct 10, 2004 | 05:43 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
As long as the items added are functional unlike the stick on rear brake ducts then you are a poser. If you put Z06 badges on a coupe then you are a poser
Now a forum member with forum name "18 wit a vette" then you are a troll
Old Oct 10, 2004 | 05:56 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
" wit a vette".
Old Oct 10, 2004 | 09:36 PM
sharpvet03's Avatar
sharpvet03
I have seen some that do not look identical to the Z06's,maybe you could get a set that matches your car-that would be sweet
Old Oct 10, 2004 | 10:02 PM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
If i put the HUD in my 2004 Trailblazer...does that make it a C5 coupe??? If so....i could always use another c5.!!!!!!
Do what you want to your car and dont worry what others think!!!!!
Old Oct 11, 2004 | 01:54 PM
IMO putting the Z06 rear brake ducts on the car is just fine. I did it to mine and like the look and they are functional. If you like it, go for it.
Old Oct 11, 2004 | 04:06 PM
DudeWheresMyVette's Avatar
DudeWheresMyVette
From: NYC / Naples, FL C5 under construction! Arancio Atlas (Lamborghini Metallic Orange) comming soon! :)
Unless you plan on tracking the car don't even bother. Why break up the lines on the side if you dont need to?
