Help!!! Dead Opitma
Old Oct 13, 2004 | 09:29 PM
willsco's Avatar
willsco
Cruise-In III Veteran
Default Help!!! Dead Opitma
I haven't drive the car in a week or so, and my Optima Red Top is dead. I am not familiar with these batteries. I had it on a 1.5 AMP charger for a couple hours, I just don't think that my charger is big enough to give it enough juice. I hate to ask, but can the car be jumped off? If so, can I attach the cables to the top of the battery, or do they have to be where the connection is made on the side?
Old Oct 13, 2004 | 11:13 PM
Dave68's Avatar
Dave68
AGM batteries like to be charged with 10-20 amps. In fact, AC Delco recommends 20 amps for their AGM batteries. You can jump the battery (top terminals are probably okay), but it's unlikely that a drive will charge the battery completely. If you don't have a strong enough battery, you should take it out of the car and to a place that does. Then, you should have your charging system and any possible drains checked for proper function/existance.
Good luck!
Old Oct 13, 2004 | 11:17 PM
Shortimer's Avatar
Shortimer
Good advice. If your redtop won't hold a charge there might be a drain or charging problem. They're pretty good batteries.
Old Oct 13, 2004 | 11:19 PM
FDA's Avatar
FDA
Old Oct 13, 2004 | 11:57 PM
CRWDDYZ's Avatar
CRWDDYZ
Gotta be a drain or charge system problem.
Not to hijack your thread....but what is the difference between the Red Top and the Yellow Top Optimas ?
Price ? Amps ?
Old Oct 14, 2004 | 04:40 AM
Richin Chicago's Avatar
Richin Chicago
Originally Posted by Dave68
AGM batteries like to be charged with 10-20 amps. In fact, AC Delco recommends 20 amps for their AGM batteries. Good luck!
But the Optima is not a Delco AGM. Optima's should not be charged at more than 10 amps with a battery charger.
"Battery charger:
13.8 to 15.0 volts, 10 amps maximum, 6-12 hours approximate."
"All limits must be strictly adhered to"
http://www.optimabatteries.com/publi...cal_specs.html
Old Oct 14, 2004 | 06:46 AM
ooh yeah's Avatar
ooh yeah
They have a 3 year free replacement take it back to the place you bouhgt. First find out whats draining her. I left the lower int. lights on and didn't know it to it was to late.
Old Oct 14, 2004 | 07:30 AM
Patches's Avatar
Patches
Depending on how discharged it is, it could take up to 2 days to get a full charge with a 1.5 Amp charger. I have a Battery Tender Plus and it can take 12 hours or more to regain a full charge if the car has been sitting for a week or more. It once went dead after about a month of no use with the alarm set and it took over 2 days to get a full charge. The low amperage is the main reason for the slow charge.
If I leave the alarm off, I have minimum battery drain so I leave the charger on it if I plan on not driving it for a while with the alarm set. Let the charger do it's job before you take it back for replacement. Optima will honor the warranty if you find it is defective.
Old Oct 14, 2004 | 09:30 AM
Blue Lion's Avatar
Blue Lion
C54-the red top is their regular battery. The yellow top is for cars with higher drains--stereo add-ons, etc. Go to Optima's webpage and they'll explain it all. The red top is good enough for most of us here, myself included.
Willsco--I agree with the earlier posts regarding your battery. Good luck.
Old Oct 14, 2004 | 10:02 AM
MDLIFE's Avatar
MDLIFE
Default dead optima battery
I have a friend whose red top battery regularly went dead when parked for more that 2 days (98 C5 vert). He finally found out the cause. He left the keys in the ignition in the garage and apparently the interior lights remained on. Removed keys..problem solved. Has anyone else had this same issue?
Old Oct 14, 2004 | 07:24 PM
willsco's Avatar
willsco
Thanks for the advice. I took it to Advance Auto Parts, they told me it was dead, and wouldn't take a charge. I am not sure what has drained it.
Now the bad news, I couldn't find my receipt. I took it back to the same location I bought it, which at the time was a Discount Auto Parts. Discount got bought out by Advance Auto Parts. My record of purchase is not in the system any longer since the buyout a year and a half ago. The manager wouldn't exchange it. I even decribed what the Optima display in the front of store looked like, and one of the salesmen remembered that. I sent an e-mail to the corporate customer service department explaining everything, so I should be getting a call from the regional manager soon. Hopefully he will make it right.
Old Oct 14, 2004 | 08:11 PM
sharpvet03's Avatar
sharpvet03
Glad to hear that it turned out to be the battery,good luck getting it replaced
Old Oct 14, 2004 | 08:16 PM
Blown's Avatar
Blown
Are you in Ms? I didn't realize Discount had any stores in Ms?
Call the store that wouldn't help you and ask for the phone number to their regional office. You will reach a regional secretary and explain to her that you have a battery that you purchase from Discount etc and you cannot get it warrantied. Ask her to speak with the Division Manager responsible for that store, if he will not satisfy you then contact the regional office again and ask to speak to the RVP which is the Regional Vice President. Be polite and courteous...it always gets you farther than asking like a jerk in my opinion.
PM me if you have any problems reaching someone.
Old Oct 14, 2004 | 08:38 PM
BIG Dave's Avatar
BIG Dave
The website says:
"In the event of failure, retain your original receipt for proper issuance of credit. Claims without proper identification of purchase date will result in adjustment from the date of manufacture."
I would think if it was manufactured less than 3 years ago, you should still be able to get a free replacement.
Old Oct 14, 2004 | 09:07 PM
WWK888's Avatar
WWK888
Just because the battery was dead doesnt mean that was the original problem. Once the battery is replaced you will still need to check your charging system.
BTW, the Yellow top is a deep cycle battery which can withstand many discharges and charge right back up. As already mentioned it is ideal for vehicles with aftermarket stereo systems requiring more power. I use it as my car sits for several weeks sometimes between drives. It has started up every time sometimes after 5 weeks of sitting.
To Help!!! Dead Opitma
