Column lock?
Old Oct 22, 2004 | 09:26 PM
NancyK7's Avatar
NancyK7
Default Column lock?
I 've owned 3 C5's, '97,'98,'01. I never experienced column lock. Which model years were affected by column lock, and will it be a problem on the C6?
Old Oct 22, 2004 | 09:43 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
I believe most of the earlier C5's, up to '01 or so, may experience this. Not sure about the C6's. I installed a column lock bypass and have not had any problems since.
Old Oct 22, 2004 | 09:56 PM
Beltrami's Avatar
Beltrami
don't quote me but i believe the recall was for most if not all C5 model years. the fix is different for the auto and the manual transmission. many have taken the aftermarket bypass route, some like me the recall, (i have access to a very good service department). from what i have read over the last couple of years it is more of a matter of when it would happen rather than if it would happen.
Old Oct 22, 2004 | 10:26 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
MN6's from 97 - 04
A4's from 97 - 01..
Old Oct 23, 2004 | 12:26 PM
Seems like all the C5's are subject to the column lock problem. Hopefully they won't have it in the C6, but time will tell.
Old Oct 23, 2004 | 02:49 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
Its a different system in the C6 but a friend who has had his new C6 about a month has already had it towed in for the column being locked. Here we go again.
Roy
Old Oct 23, 2004 | 03:16 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
hope it never happens to me
Old Oct 23, 2004 | 03:34 PM
Dave68's Avatar
Dave68
My actuator lasted 1500 cycles before quitting. This'll give you an idea as to how long the average C5 actuator will last, so heed the warning.
Old Oct 23, 2004 | 03:52 PM
QS-ZO6's Avatar
QS-ZO6
Default Steering in the right direction!!
The Column lock issue has effected everyone with a C5 except for 2004's. I saw 1997 through 2003 C5's comming in the shop that I was associated with prior. I am PLEASED to announce that Motorsport Technologies is now carries the Column Lock Bypass. Its a snap to install and will prevent any of us from having this problem. It cost $54.95, so let us know if you need one and we can send it right out!
To Column lock?
