Help needed... convertible owners.
Just noticed last night that the passenger window is not tucking under the convertible top when fully rolled to the top. The window is overlapping the canvas on the corner of the window and is beginning to wear the canvas arrrrgggggghhhh! Anyone experience this problem and/or have any suggesstions. Thanx.
Happened on my drivers side when the car was new!! All the dealer could do was adjust the door. Since then it has been o.k. The top isn't in bad shape from it though I should have had it replaced.
Just got a 2004, same problem. Doesn't seem to be any cure looking at the bottom of the door, only tip in or out adjustments. Looks like door hinges have to be adjusted.
Mine did it as well in the same spot. I had the top replaced under warranty, and I have kept and eye on the new top (about 2 years now). I see some rubbing, but I try to keep the windows down now when closing the door. Which isnt hard since the top is down most of the time when I drive it anyway.
1 Post
St. Jude Donor '03-'11
When I bought my 99 used, it did that, and had worn a small hole in the edge of the fabric. In addition to the window adjustment, you can adjust the top as well (and it's easier). Fold the top up to the point where the front section is vertical. You will see an adjustment screw on the horizontal section pointing towards the front of the car. Adjust that (I can't remember in or out) to alter the profile of the top. That might cure it.
Location: mamaroneck ny www.prodigyperformancecoatings.com
i had the same prob on my 99 vert..you can adjust the window to help the problem but from expeirience,its the vert top stretching and breaking in.over time the corners seem to lay down and thats when the corners are hit by the door glass.i replace my top and the problem went away..for now!!! if any of you guys are looking to get a replacement top,i have a gm oak top that is brand new..i will sell it for 430.00 shipped if you guys are in need of one..to not screw up the thread,you can e-mail me directly...good luck to everyone with this on going problem..joe
1 Post
St. Jude Donor '05
CI VI Veteran
I just noticed this on my vert about 3 days ago. I can hear a "thwap" as I open the door.
Being a bodyshop guy, adjusting the glass a hair forward will cure it... just doesn't bother me enough to mess with it.
I'm sure when the corners get worn, I'll be pissed I didn't adjust it.
Mark
Mark
99 Vert leaked when you washed the it, by the middle of window and I don't ever spray the car. I use the hose with no nozzle or force and it leaked. My 04 does the same. Don't know if the 04 leaks in the rain as I haven't been caught yet, but the 99 leaked both times caught in the rain.
Thanx a ton folks... this board is incredible. Crazy though... my wife returned tonight from work and the passenger glass was not overlapping the top. My conclusion is that the top must move slightly... it was quite windy here in Vegas today. Anyway, I will keep an eye on it and report any success with your suggestions.
Read the following link for adjusting the top.
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
5th pic, not the yellow arrow, but the set screw and jam nut below it.
What you want to adjust are the tension and set screws on either side of the top frame where it attaches to the body. This will cause the top to have a tighter strech and lift the edge just a bit for the window to clear properly. Still catches on occasion, but that is probably due to relative humidity and the fabric relaxing a bit.
It fixed my issue. I have also played with the tip in, but for some reason, that adjustment made little change.
1 Post
CI 6-7-8-9 Veteran
St. Jude Donor '07
Now I gota go check mine closer
I use window valet (which I Love) most of time. It runs the windows up into the rubber seal and allows for less door slamming to get it closed. I drove with top down most of summer about 7K mi.
This is a very old problem. Had it back in 98 with mine. Checked all adjustments doors and window and they were at spec. GM paid to have the top clearenced. They cut and re-stiched around the window. That was 113K miles ago, been perfect every since. Don't just go in and start making adjustments to the window. Measure twice cut once!
The upholstry shop did a perfect job, could not tell. Maybe because the owner had a vert as well and had done a lot of them.
