Voltage Problem?
Old Oct 29, 2004 | 08:26 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Default Voltage Problem?
04coupe, 2300 miles.
Just noticed that with my headlights on, when I turn on my turn signals, the stereo lights flicker in unison with the turn signals. My volt meter display also flickers in unison with the turn signals...13.8, 13.6, 13.8, 13.6 over and over. It stops when i turn off the turn signals. This will be my first dealer experience with this car and from reading all your dealer experiences, I'm scared to take it in. I've always had excellent service at the Cadillac dealer, but Chevy might be a whole different story.
What do you think it is, or is it normal to do this.
Thanks, Jeff
Old Oct 29, 2004 | 08:51 PM
Jimbad's Avatar
Jimbad
St. Jude Donor '06-'09-'10-'11
I'm sure that those more knowledgeable than I will respond,but I am guessing that what you describe is not "normal". As far as dealers go I believe that this is a case-by-case situation, irrespective of the make of car.
Old Oct 29, 2004 | 09:09 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Check to see if the battery is leaking. You may have a bad cell. Under load it breaks down. I would think it's the battery. To new a car for it to be much else. My .02
Old Oct 29, 2004 | 09:12 PM
1Patriot's Avatar
1Patriot
Sounds like a loose ground.
Old Oct 29, 2004 | 09:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds normal to me !! Your voltage will fluctuate with other loads. I have 2 other C5's They both do it! As long as your minimum voltage does not drop below 13 volts I would say it is NORMAL.
BC
Old Oct 29, 2004 | 09:15 PM
JeffC5's Avatar
JeffC5
I just checked my battery and it looks fine...don't see any kind of liquid or corrosion around it or in that pan the battery sits in. I'll look at some grounds tomorrow. Where would the grounds be???
Thanks, Jeff
Old Oct 29, 2004 | 09:50 PM
JeffC5's Avatar
JeffC5
Bill, then why do the lites on the radio buttons flash or fluctuate with the turn signals? Also, just to test it to see if it got worse, I turned on the rear window defogger. The volts dropped to 12.6 and 12.8 back and forth with the turn signals.
Jeff
Old Oct 29, 2004 | 10:26 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
BC
Sounds normal to me too
Listen to this Bill Curlee guy, he know his voltage, as for me IM just re-volting
If your not seeing a "charging system fault" display, you're just seeing a fluctuation in DC voltage..
Old Oct 29, 2004 | 10:32 PM
JeffC5's Avatar
JeffC5
Thanks everyone....i'll just let it go then. If it doesn't worry you guys (the experts), then It doesn't worry me. I'm actually relieved not to have to go to the dealership. I bought my car out of town and will most likely use a local dealer for repairs and that kind of worries me.
Thanks again,
Jeff
Old Oct 29, 2004 | 10:59 PM
Evil-Twin's Avatar
Evil-Twin
Thanks again,
Jeff
we get paid very well here on the forum to help keep you away from the dealer, if we can. Soon as me and Bill save up enough money from the forum we are going to buy each other a beer
Old Oct 30, 2004 | 05:56 AM
JeffC5's Avatar
JeffC5
The forum started me out at the bottom. The pay is lousy, but as soon as I get my forum promotion, I'll start saving and buy you both a beer...or at least one you can share. lol
Jeff
To Voltage Problem?
