Help with targa top
I just got a used top today off a 2001 coupe. The top is in really good shape as well as all the weatherstriping. When i put the top on, it is really tight in the front and when i lock it in it seems to fit well.
Heres the problem, when i go to shut the door with the window rolled up, the top of the window hits that black plastic "clip" on the side of the targa top that pushes the window against the weatherstriping.
Has anybody incountered this problem, or know how to fix it. Is there any way to adjust the hight of those black clips on the side of the top.
By the way, the top is from a 2001 and my car is a 2004. I know they are both C5's but just thought i would let you know.
Thanks,
Mike
The service manual says that wind noise under 65mph could be caused by a gap where the coupe lock pillar weatherstrip overlaps the roof weatherstrip. It recommends that you grasp the middle of the side of the coupe lock pillar weatherstrip with one hand & with the other hand slide the weatherstrip upwards in the retainer so it tightly contacts the roof weatherstrip.
The second possible cause could be that there isn't enough pressure between the window & the lock pillar weatherstrip. You can adjust the door window tip in so that the window is flush to 2mm inboard of the lock pillar weatherstrip retainer. If you want to do the tip in you'll need a #6 inverted Torx socket. The procedure is found on pg 8-1134 of the service manual in Volume III.
I'll sketch it out just in case you don't have a manual.
1 Position the window fully up.
2 Remove the large access plug from under the front of the door.
3 Loosen the window regulator front channel mounting nut.
4 Remove the reflector from the trim panel.
5 Loosen the jack screw jam nut.
6 Adjust tip in with the jack screw.
- Turn the jack screw clockwise to tip the window outward.
- Turn the jack screw counterclockwise to tip the window inward.
- One turn of the screw equals approximately 1 N-m(0.04") change at the top of the window.
7 Tighten the jack screw jam nut.
8 Lower the window.
9 Tighten the window regulator channel front mounting nut.
10 Raise the window & check the alignment.
11 Install the access plug under the front of the door.
12 Install the reflector in the door trim panel.
The third cause of wind noise could also be a gap where the roof panel side weatherstrip & the roof panel weatherstrip retainer meet at the front or the rear corner of the roof. The air/ind noise sounds like it is coming from an upper corner of a door window. The manual suggests:
1 Remove the roof panel.
2 Remove the screw from the end of the weatherstrip.
3 Partially remove the weatherstrip by carefully peeling the end of the weatherstrip from the top assembly.
4 Apply a bead of urethane based windshield resealant 6mm (0.02") in height.
- Across the end of the weatherstrip retainer.
- From the end of the weatherstrip retainer 20mm (0.8") along the upper edge of the retainer.
- From the end of the weatherstrip retainer 20mm (0.8") along the roof panel at the junction where the roof frame is bonded to the roof panel.
5 Install the weatherstrip & the attaching screw.
6 Clean up any excess sealer with solvent & a clean rag
Important: When installing the roof panel make sure the front edge of the rear roof bow weatherstrip does not roll rearward & block the drain trough down the middle of the weatherstrip.
7 Install the roof panel.
If you have the manual you can find the text & pics at 8-799 - 8-803
If you have the dealership do any work make sure that they don't break the tabs off your door reflectors.
I'd tend to think that the window tip in would help to solve the problem. I had the same problem at speeds over 120mph.
Thanks again,
Mike
8 Lower the window.
The window tip in adjustment should do the trick. If you are one of those people that it helps to "see it". You can check out the instructions here:http://www.***-internet.com/johndenn...to/how_to.html
Just select the window tip in adjustment from the menu. If it turns out you need the blow-out clip adjustment there's one there for that too.
Paul
I bought it from a CF member, im not sure of his screen name, but his name is Tommy and he's from NY. A very nice guy, i drove to his house and picked it up on Sun. I was nice to ba able to go and see the top and how it fit before buying it. Thanks again Tommy
and thanks talon for the link
