VaraRam vs Blackwing
Old Nov 1, 2004 | 08:10 PM
wolfman04's Avatar
wolfman04
Default VaraRam vs Blackwing
I can have the VaraRam System installed on my 04 coupe for $425.00 or buy the Blackwing for around $280.00. Does the VaraRam give you better performance then the Blackwing? I don't mind spending the extra money for better performance what do you all think?
Old Nov 1, 2004 | 08:21 PM
HummelS's Avatar
HummelS
Price sounds a liitle high for the Blackwing, or is that installed?
Old Nov 1, 2004 | 08:25 PM
wolfman04's Avatar
wolfman04
Price from Mid America Motorworks.
Old Nov 1, 2004 | 08:45 PM
roscoe118's Avatar
roscoe118
You will get a slight bit better performance from the Vararam, but not enough to notice (between the two) in the seat of the pants.
You will be able to install the Blackwing yourself, saving a few $$$ as well. You should be able to get one for less than $280. Try a couple of the supporting vendors on the right side of the page.
Vararam is a good bit more difficult to install (if you want to do it yourself). If you intend to race the Vararam is probably the better choice.
Old Nov 1, 2004 | 08:59 PM
yellow viking's Avatar
yellow viking
Also, since you have a 2004 C5, if you have a warranty issue, MAF, A/F, etc., the dealer may point the finger at the intake system. You will spend a couple of hours pulling it out, and then a few more hours putting it back in, or paying someone $100 to do so. Blackwing to stock, 20 minutes.
Old Nov 1, 2004 | 09:02 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Love my Vararam. About an hour and a half install time but, well worth it IMO.
Bob
Old Nov 1, 2004 | 09:16 PM
ZaydeZ06's Avatar
ZaydeZ06
Old Nov 1, 2004 | 11:38 PM
Vettegator's Avatar
Vettegator
Dont buy it from Mid America.
I got my Blackwing for under $200 from a forum vendor, and I installed it myself in under 30 minutes.
Old Nov 2, 2004 | 12:08 AM
shurite44's Avatar
shurite44
Default vararam
I have a vararam and I love it. Dont know much about the blackwing. As far as the install goes I spent at least an hour and a half cussing alone. I think it took my cousin and I about four hours to install.
Old Nov 2, 2004 | 12:32 AM
LeMansBlue04's Avatar
LeMansBlue04
For a long time the VaraRam has had a reputation for using a low quality filter. Someone once posted a picture of their MAF screen full of trash after a few months of using the VaraRam.
For those of you using the latest model what is your take on this. Does the VaraRam filter seal properly and take dirt out of the intake air effectively?
Old Nov 2, 2004 | 03:34 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
I purchased my Vararam a couple of months ago. The filter that came with it seems like a good piece and does a good job of filtering the trash.
I pulled it apart and I guess while there's no way I can prove it is or isn't working, the trash was on the outside of the filter...
Mark
Old Nov 2, 2004 | 03:38 AM
davisce's Avatar
davisce
Default VaraRam ~ Blackwing
Terk,
One thing to keep in mind. . . . none of the above (VaraRam or Black Wing) are "RAM AIR" systems. The only "Ram" or "Forced" induction comes with a "Supercharger or Turbo". The "VaraRam" and "Black Wing" do about the same thing. . . . . provide for better airflow to the intake, one just costs less (the Black Wing) and is easier to install !
I'm running the "Black Wing" on my 1999 C5 Coupe, 6 Speed and it works great, but that's just me. . . .
Cecil
Geman American Corvette Club
of Baden-Wurttemberg
Heidelberg / Mannheim, Gemrany
Hometown: Bore Alex. Virginia,
call Fort Laurdale, Florida Home these days.
Old Nov 2, 2004 | 04:21 AM
freemanj's Avatar
freemanj
I just had my Varaam 2b Installed Last Saturday for $80.00! All I can say is wow! Went on a high speed run on I-95 and it's totlayy different car! This Setup is similar if not better than the same type of Ram air that are on the Pontiac Firebird WS6 and the SS Camaro! And as you all know they pull really hard at WOT. Turning air into fuel really does work. I was skeptical at first but now I am a believer. I'm not sure about the black wing but my neighbor down the street took out his blackwing and installed the Varaam 2B and his comments after his run was one word! (WOW)! To each his own but the Varaam is worth the extra Chetta!
Old Nov 2, 2004 | 04:25 AM
freemanj's Avatar
freemanj
Originally Posted by davisce
Terk,
Cecil
Disagree there my friend!
Varaam is a Ram Air system but it is not a forced Ram Air Induction! While theory is the same they are distinctly different. Ram Air is done my motion and free velocity whlie Ram Air Forced Induction is done through Forced Air Velocity.
Old Nov 2, 2004 | 04:32 AM
shurite44's Avatar
shurite44
Default vararam replacement filter
High I agree that the vararam filter is a little flimsy. Here is a link to the K&N filter that will fit the vararam.
http://www.performanceintl.com/shop/...522+&submit=Go
Old Nov 2, 2004 | 04:58 AM
EHS's Avatar
EHS
...Try a couple of the supporting vendors on the right side of the page.
Oh my goodness, so much stuff here, so let's start at the top.
Vendors are on the left?
Old Nov 2, 2004 | 05:00 AM
EHS's Avatar
EHS
There is no warranty issue in real life -- it's theoretical.
I've been to a number of dealers with my Blackwing over the last four and a half years. They all loved it.
Find a dealer who likes Corvettes.
To VaraRam vs Blackwing
Old Nov 2, 2004 | 05:04 AM
shurite44's Avatar
shurite44
Default Warrenty
I believe the dealer must prove your mod caused the problem to deny warranty work. My experience with any vehicle is the dealer trys to deny the warranty work anyway reguardless of any mods until you hold firm and let them know you are going to big a much bigger pain in the *** then GM is.
Old Nov 2, 2004 | 05:05 AM
EHS's Avatar
EHS
Like someone earlier above said, the gains are negligible, if they exist at all.
Ignore the Vararam, get the Blackwing, which is a cinch to install.
I got mine from Richard Griffen (a/k/a as "RG") at Extreme Motor Sports -- he's a great guy, sells both, and you can't go wrong with Extreme's customer service.
The Blackwing is a lot easier to install, and performs the same.
Old Nov 2, 2004 | 05:08 AM
shurite44's Avatar
shurite44
Default good one, oops
