Question re: tire spin
Old Nov 3, 2004 | 12:48 PM
bozo4onion's Avatar
bozo4onion
Hondas, Kias, Burnouts unnecessary and don't make the Vette look fast, Wasting tire rubber? Who are they selling Vettes to these days. We're watching you guys.
Old Nov 3, 2004 | 12:56 PM
robvuk's Avatar
robvuk
Originally Posted by MagikDraggin
I have a 3 month old 2004 coupe with the A4 and 2.73 gears. This may sound odd, but it will only squeal the tires a little off the line and no chirp with the 1-2 shift at wide open throttle.
HOWEVER, at half throttle, it will spin the tires off the line as well as chirp the tires on the 1-2 upshift. Go figure that one!
And by the way, it is not so much horsepower that spins the tires off the line as it is torque. Also, at the rear wheels, your stock vette is probably only putting around 285-290 ponies to the pavement. That 350 figure is figured at the crankshaft.
What the 3.15's and 3.42 gears do, is get the rpms up more into the "power range" quicker where that power really is. Same with a higher stall torque converter.
Welcome to the forum, also. Don't forget to wave
This is the point that most of you are missing: You have 350hp at 5800rpm! When you stomp it from a standstill at 1000 rpm just above idle, you probably have 100hp! On top of that, you've got huge tires to spin. Once the car gets going and the rpm range begins to approach 300hp, you're already going 30 or 40mph. That's why you can get a chirp on the upshift. You're doing 45mph but you're right in the good powerband when it shifts. This is why they make 3.15's and high stall converters. A higher rpm stall converter allows you to come off the line at 2-3k instead of 1000. It's easy with a manual because you can pop the clutch at any rpm you want. An automatic is a different story. As mentioned earlier, brake torqing is basically the same as the higher stall to a point and will definitely spin the tires. 2.73's are for economy.
Sometimes a little less throttle will chirp the tires off the line because it occurs before the weight transfer of the car increases the traction. Full throttle throws the front end up and shifts the weight to the rear which makes it harder to slip the tires but this is a good thing.
Old Nov 3, 2004 | 01:02 PM
2004vert1's Avatar
2004vert1
6th Gear
thanks for the replies...good info...was more curious than anything else...don't think the 3.15 axle is worth it for me...since I don't intend to do burnouts on a daily basis...I was just surprised it didn't do it more than anything else....regards.
Old Nov 3, 2004 | 03:45 PM
boomer 33's Avatar
boomer 33
Default Smoke em
I am on my second C5, an 03 and now an o4, both had A4's, neither will spin the tires from a dead stop without using a little brake. I am getting a tune next week from Ed Wright and see if it changes anything. Had the same problem with my 04 Yukon XL with the 8100 engine, but Westers fixed that !
Old Nov 3, 2004 | 03:51 PM
tdb's Avatar
tdb
Try removing any unnecessary rear end weight including any "butt jewelry"
Old Nov 3, 2004 | 05:14 PM
M_T_0's Avatar
M_T_0
mn6 here and with bad gas WOT will not spin the tires if i dont drop the clutch. with good gas and easy on the clutch (let the clutch out at 900 rpm then step on it) 300 feet of black lines and lots of smoke. could be fuel related.
More Than Zero
Old Nov 3, 2004 | 05:16 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
More Than Zero
2004vert1 has a A4....
Old Nov 3, 2004 | 05:18 PM
Torchy2000's Avatar
Torchy2000
Originally Posted by Randy's C5
I have an A4 with the performance axle (3.15) and can boil the tires on launch as well as squeal the tires on 1st to 2nd shift (in OD). IMO, this would indicate that 2.73 vs 3.15 is the difference since I have no other "performance mods".
My A4, 3.15 will git'er done!!
Old Nov 3, 2004 | 06:31 PM
Vette-Dream's Avatar
Vette-Dream
I just bought a 2004 (Automatic) vert....from a dead stop, I floored it for the first time yesterday (with traction control OFF) and there was no tire spin (ie, burn out).
I was surprised...assumed there would be massive smoke. But instead nothing but a squeak...
I assume this was done deliberately to give a faster jump off the line...is this correct?
Welcome! I have the A4-2.73 as well, love cruising with it, mileage is nice, and the low rpm/noise is terrific for a vert. But I don't think there was any deliberately when GM's choose the 2.73's to get them to jump off the line faster. Even though every stock A4 will put down exactly the same hp from a standstill the shorter geared cars will have much more torque applied and so will naturally 'spin' quicker.
I love knowing I can mash the pedal without losing traction, never worrying about whether it'll spin on me or not. But when you want to spin the tires, and if anyone says they've never wanted to then they'll either lying or in a coma... just hold the brake. It's the only way I was able to get mine to do this... old tires
Old Nov 3, 2004 | 07:01 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
My 99 Coupe has 2.73 gears and I have no trouble spinning the wheels at about a 1/4 throttle. I've got to be real careful when I pull out and do a 90 degree onto a street as it breaks loose.
I did play with a new Blue Z0 on the freeway one night and left him wondering. He followed me to the mall and wanted to see that LPE engine. He liked it.
Old Nov 3, 2004 | 08:39 PM
Baron138's Avatar
Baron138
Default I noticed this too.
Then I started to think, The techs designed this car for performance. This means hooking up and going as fast as possible. Tire spin looses time in races. A lot of man hours and technology went in to making these cars "glue" to the road. A good smokey burnout is so cool though.
Old Nov 3, 2004 | 08:59 PM
I X L R 8's Avatar
I X L R 8
so, can anyone definitively confirm that the 2.73 axle is the reason the A4 won't spin tires?...I just find it suprising that with 350 rwhp I can't smoke em...also, it my understanding that the 3.15 axle doesn't add horespower and improves 0-60 by less than 1/4 second...any other A4 owners with 2.73 in the same boat as me????
I was in the same boat as you...............until i dumped the 2.73 shyt gears and installed 3.42's
HUGE difference
Old Nov 3, 2004 | 09:01 PM
  #33
VLVETTE's Avatar
VLVETTE
2.73s turn off traction control apply brakes run her up to about 1500 rpms or alittle more then let off on the brake and punch it she will leave a few dollars worth of rubber on the ground
Old Nov 3, 2004 | 09:05 PM
  #34
I X L R 8's Avatar
I X L R 8
HUGE difference
Old Nov 3, 2004 | 09:06 PM
  #35
ZO6vettepilot's Avatar
ZO6vettepilot
Try turning off the traction control, or put the active handling in Competative mode.
z06vettepilot
Old Nov 4, 2004 | 08:15 AM
  #36
loudsam's Avatar
loudsam
Welcome to the forum!!!
I have a stock c5 with the 3.15 axle and I "have to be careful" or my stock eagle runflats will spin without provocation when I don't want to "burn rubber". Once it happened right in front of a County Sheriff. He followed me for 3 or 4 miles making me nervous as heck. My wife has unintentionally "burned rubber" while I was with her, (the only time I'll let her drive it). It must be the rear axle that makes the diff!
Old Nov 4, 2004 | 08:47 AM
  #37
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
I can spin the tires in 1st, 2nd, and 3rd gear. Oh yeah, I have a 6-speed, with a 3.42 rear end.
To Question re: tire spin
Old Nov 4, 2004 | 09:18 AM
  #38
Mike04's Avatar
Mike04
HUGE difference
I also put a 2800 stall converter in...I can leave 20+ feet of rubber off the line.
Old Nov 4, 2004 | 11:17 AM
  #39
SLWRNU's Avatar
SLWRNU
More Than Zero
Please tell us what brand of gas you're using. I have an 04 CE Vert MN6 and think it's pretty quick, but 900 RPM and easy on the clutch leaves 300' of rubber? That's a football field length. You'd be well into the rev limiter long before that without shifting to 2nd ( I speak from experience here). Am I the only one that apparently got a "dog" from the factory?
Here I go again on wild statements, i.e. bone stock A4 with 2.73 running 12.s, 345 RWHP on stock C5, blah, blah.
Old Nov 4, 2004 | 12:34 PM
  #40
xwing's Avatar
xwing
The beauty of a manual transmission, is that you can smoke the tires on any car. I can smoke the tires in my < 100 HP Datsun pickup of I want.
