Have any of you high speed guys felt it gets light or floats up there about 150 ?? And bump steer ?? I just got mine a month ago or so and I felt ( 31psi in frount tires) that mine gets light in frount and seeems to want to wander ?? Do I need alignment checked ? thanks
I felt the exact opposite, car was very stable above 150, I run 30psi cold w/ runcraps. it could be the aero difference between the coupe and Z06 (coupe is faster, Z06 is quicker). It could also be that something is a little off but still within specs. Don't buy the "we put it to factory specs" line get the printout from them.
another random thought is that the rake could be off if you lowered it. I've seen a lot of C5s lowered more in the back than in the front and that could have a big affect on high speed aero. The front is suposed to be about 1" lower than the back
183-184! Car is lowered with good alignment and rev limiter set to 7,000. No problems with lightness or wander. More HP would go faster! Come on C6 Z06!
141 in about 20 seconds of insane acceleration on a couple miles of very straight and relatively clear two-lane road. The few cars I passed going the other way must have had that Mexican taco problem.
The one thing I did notice? Lots of wind noise. The windows suck outward about about 80.
I hit 180 on A60 a month or so ago, 3 lanes, clear sky, no traffic, no speed limits, and no turns
I did my run on 60 just a couple of weeks after it opened, Sunday morning heading to Bitburg for some DE with the Piston Club the to the ring for some lapping, I was the only car on both sides of the bahn!!!!!!!!!!!!! I sure do miss Germany.
CPT ZO6 we have to get you to VIR ( Danville VA) for some track time. May not get 150+ but still lots of fun.
I hit 145 creasting the hill on the back straight of VIR. One has a come to Jesus meeting at that speed when you are about to creast the hill, you dont see any track in front of you only air. then keep the peddle to the floor to 151-152 to hit the brakes at the #5 marker.
I can't wait to back into racing, BTW almost every curve and hill on the nurburgring was blind!!!!!
