Scratched Glass?
Old Nov 8, 2004 | 10:30 PM
ecook's Avatar
ecook
Default Scratched Glass?
Anyone have experience with repairing a scratch on your back hatch?
Old Nov 8, 2004 | 11:13 PM
Shortimer's Avatar
Shortimer
If the scratch isn't too deep you might have some luck with a glass polishing kit. I think you can find them at AutoZone or Pep Boys etc. Most glass installers will polish out minor ones for a fee. Never got a price so I don't know if it's fair or robbery. Be careful when working you glass. If don't improperly you could make the situation worse.
Old Nov 9, 2004 | 08:11 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You'll be sorry, leave it alone, it can not be, buffed or polished.
Old Nov 9, 2004 | 10:08 AM
ecook's Avatar
ecook
This is the only thing I found anybody use this? http://www.glas-weld.com/
Old Nov 9, 2004 | 10:19 AM
robvuk's Avatar
robvuk
That's for filling cracks. It works marginally. It won't do a thing for scratches.
Good luck
Old Nov 9, 2004 | 11:29 AM
ecook's Avatar
ecook
guess im sh@# out of luck unless I replace the back glass
Old Nov 9, 2004 | 11:53 AM
n2spd's Avatar
n2spd
The first guy that tinted the back glass left a scratch from one side to the other right in the middle. I put 5% on the back and you cant see it anymore
Old Nov 9, 2004 | 04:43 PM
SilverMN6's Avatar
SilverMN6
This is exactly why I would not let any tint guy touch my car. The way some of them trim the tint is exactly the way you would score glass to cut/break it.
Back to the question at hand - it is probably better to just live with the scratch if you can. I have had glass guys try to remove a scratch on another car. Naturally, they don't like to turn down business, so they tried. They did get it smooth, but when you looked through it, the view was all distorted.
Maybe tinting over it would help.
Old Nov 20, 2004 | 09:23 PM
ecook's Avatar
ecook
Just wanted to update this thread. I figured I would give a Guy who had the www.glas-weld.com system an opportunity to get the scratches out of my rear window. He was able to remove around 80-90% of the scratch. You can not tell the scratches are there now unless you really really look for them.
Old May 21, 2012 | 04:44 PM
Corvette_Ed's Avatar
Corvette_Ed
This is exactly why I calmly explained to my tint guy that if he scratched my hatch, he'd have a new paperweight and I'd have a new hatch.
Seriously though, if you go with someone who is experienced with high end cars you can avoid the problems because they know how much it will cost them to replace your glass for you. My guy used a marker to outline the cut, then took the tint off of the car and hung it from a big whiteboard he'd rigged with clips. Once he had it hung he made all of the cuts on the board instead of on the car. Smart guy, and one I would recommend for anyone here in north Texas.
Old May 21, 2012 | 05:19 PM
Corvette_Ed
Originally Posted by Glass Restoration
I have a tint guy in Clearwater Florida that uses a vinyl cutter, more commonly used by sign graphic guys. He has specs for glass sizes and punches the specs into his computer. The cutter cuts the film to size so that he does not have to do any cutting on the car. There has to be others out there that do the same.
Barry Barbas
That's a cool setup, but I imagine it's also pretty expensive up front to purchase the equipment. I'll mention it to my guy next time I talk to him. For some reason good, professional tint guys are a rarity in the Dallas area. Most of the so-called pros work for a chain store and they aren't ones who you would want anywhere near a Vette.
To Scratched Glass?
