problem with blinker
Old Nov 11, 2004 | 11:20 PM
jsingh's Avatar
jsingh
Default problem with blinker
whenever i push the turn signal lever down to signal left the clicking sound is very rapid and the blinker does not work, the bulb works fine with the hazard though, also DRL is off on the left
Old Nov 12, 2004 | 12:21 AM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Sounds like a classic bad bulb execpt for it working with hazards. How old are the bulbs? If over 5 years I would consider replacing all of them. Just to be safe
Old Nov 12, 2004 | 08:31 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
mine worked with the hazards as well.. .you have 2 filaments in the bulb... bt it needs to be replaced.
Old Nov 12, 2004 | 08:36 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
And while you're in there you should check out the housing (especially just above the bulb) - the heat of the bulbs sometimes melts a hole in the housing alowing water to drip on the bulb.
Old Nov 12, 2004 | 08:54 AM
DeeGee's Avatar
DeeGee
Once you've rplaced the bulb you may want to consider whether you disable the DRLs. Pulling the A2 fuze will disable them. Just gives a couple of DIC codes for the approach light functions which are lost.
Lots of discussion on pros and cons of DRLs but they do generate a lot of heat. Some members like tham as a safety feature. My opinion is that if the "problem driver" can't see a Vette coming best you go defensive anyhow! JMHO.
Old Nov 12, 2004 | 09:01 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
this does tend to occur.
Old Nov 12, 2004 | 09:14 AM
tT-REXXX's Avatar
tT-REXXX
Default previous posts
Replacing turn signal light's not easy job. Dealer charges close to 100.00 have seen posts about an easy way to do it.
Old Nov 12, 2004 | 09:50 PM
PaPaChoc's Avatar
PaPaChoc
I paid $35 to have the right side blinker changed! I got my moneys worth! Now I know how to do it.
Old Nov 14, 2004 | 11:36 AM
DeeGee's Avatar
DeeGee
Default Replacing the parking light/DRL bulb
Save the money guys!
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic lug in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
Old Nov 15, 2004 | 08:14 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I'd like to add that I found it tons easier if I removed the hood bumpers just next to the headlights.
BTW I siliconed the head of a 2 inch plastic christmas tree plug over the hole in the top of the light housing... hasn't burned out yet.
Old Nov 15, 2004 | 09:53 AM
roscoe118's Avatar
roscoe118
What is the # of the bulb? Is it a "standard" bulb that can be bought at any car parts store? Or do you need to get it from GM?
Thanks,
To problem with blinker
