blinker light housing...
Old Nov 12, 2004 | 08:32 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default blinker light housing...
is there supposed to be a hole in the top of it, the looks like someone poked a phillips head screw driver through it?
wonder what the PO was trying to accomplish when he did that?
Old Nov 12, 2004 | 08:41 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Nope, but a no charge feature of the C5 is that the heat the bulb produces will melt a hole in the top for you. Now you know why you've had several bulbs go bad on you. It is time to be creative or to get a new housing - or just keep replacing bulbs... You're not alone (as you already know)
another holey bulb housing post
Old Nov 12, 2004 | 08:48 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I was just going to slap a platic plate over it and silicon the living **** out of it.
Old Nov 12, 2004 | 09:57 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
if your solution doesn't include duct tape then will it hold????
Old Nov 12, 2004 | 10:25 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
hmmm... dunno. My usual solution is superglue.
Old Nov 12, 2004 | 10:45 AM
Joe's Eray's Avatar
Joe's Eray
Earlier I was thinking about getting some smoke parking light covers, will this cure the problem?
Old Nov 12, 2004 | 10:53 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
the problem is with the cheap plastic around the housing.. not the glass.
Old Nov 12, 2004 | 11:03 AM
Joe's Eray's Avatar
Joe's Eray
Im thinking also when I put a new bulb in my left light fixture to pull the fuse that keeps the DRL on. Anyone know the fuse #?
Old Nov 12, 2004 | 11:11 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
https://www.corvetteforum.com/techti...=273&TopicID=1
Old Nov 13, 2004 | 05:04 AM
DeeGee's Avatar
DeeGee
The fuze is A2 "Approach Lights". it brings up a couple of DIC codes but apart from losing the back up lights in the "approach mode everything works fine.
To blinker light housing...
