[Z06] LS1 Engine vs LS6
Old Nov 23, 2004 | 01:08 PM
bernrex's Avatar
bernrex
Default LS1 Engine vs LS6
Someone with a ZO6 ... please explain engine upgrades the LS6 engine has that the LS1 lacks.
Specifically differences in : Intake manifold, cams, valves, head, ... port sizes, Mass airflow sensor sizes, throttle body, etc.
If I put in a H/C package in my LS1 ... will it be advisable to also upgrade to those above items the LS6 engine has ... to get best performance from headers/cams.
Old Nov 23, 2004 | 02:24 PM
Charles7Mitchell's Avatar
Charles7Mitchell
The Z06 comes equipped with an on board computer with a radar device that identifies the car in front of it. If something such as a Porsche or Mustang is identified the computer takes control and does what is necessary to pass the car ahead. It can be a surprise if you don't know what's happening. The first time I passed a Porshe I did so screaming with my foot on the brake as hard as I could push.
Old Nov 23, 2004 | 03:07 PM
laron's Avatar
laron
Did that come out in 02 or 03....
Wish my 96 C5 had come with that future....
Old Nov 23, 2004 | 03:09 PM
TonyJohnson's Avatar
TonyJohnson
http://www.corvetteactioncenter.com/...06/ls1ls6.html
Old Nov 23, 2004 | 04:56 PM
bernrex's Avatar
bernrex
Thanks TJ for the Actioncenter link. It compares the 2001 model year engines ... but, gives additional changes that occurred in 2002, for the LS6 engine (405 HP). I believe no additional changes occurred during 2003-2004 for the LS6.
They show no changes in the LS1 after 2001.
Looks like the '02 LS6 differs from the LS1 in many respects. New MAF sensor, air filter housing, different camshaft and valves, new cast iron exhaust manifold, new cylinder head, different valve lift/duration and profiles, higher valve springs, and computer changes to control the above.
Can anyone else shed light on other changes in the two engines.
Also will MAF sensor, throttle body, intake manifold, and cylinder head alterations be needed when adding performance header/cams to the LS1 engine.
I feel the H/C manufacturer will know and advise me ... but, does anyone know what is really essential vs just wasting extra money w/o really needing to add them to make H/C alterations most effective.
Old Nov 23, 2004 | 06:09 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Put a H/C, FAST intake, LT headers, intake on your LS1 and you'll be way ahead of an ls6.
Old Nov 23, 2004 | 07:11 PM
AU N EGL's Avatar
AU N EGL
Shhhhh
To LS1 Engine vs LS6
