Gm Did Me Wrong
Old Nov 30, 2004 | 03:30 PM
vetteturbo's Avatar
vetteturbo
Default Gm Did Me Wrong
I SENT MY 03 ZO6 TO BE REPAIRED, DONT TRUST MY LOCAL DEALER SO SENT THE CAR 1100 MILES AWAY..UPON INSPECTING, THEY FOUND THE CAM BOLTS--1 BACKED OUT, THE OTHER BROKE IN HALF, CAUSING THE TIMING CHAIN TO DROP--RESULTING IN BUSTED HEADS, BUSTED BLOCK, EVERY PISTON HIT EVERY VALVE DESTROYING MOTOR. THEY SAID THIS WAS NOT MY FAULT-IT WAS A PROBLEN FROM GM SO THEY TOOK THE MOTOR TO THE DEALERSHIP HEADS OFF, TIMING COVER OFF SO THEY COULD SEE THE OBVIOUS PROBLEM-AND NOT FROM SOMETHING I DID..GM FINALLY COMES TO LOOK AT IT AND IMMEDIATELY WALKS OUT SAYING NOT COVERING IT BECAUSE THE DEALER DID NOT REMOVE THE ENGINE--A VERY GOOD ASE CERTIFIED AND BEYOND DID. THOUGHT THAT IT WOULD BE FASTER TO GET A REPLACEMENT ENGINE..CAR IS UNDER WARRANTY---WHAT IF I HAD IT SOMEWHERE THERE WAS NOT A DEALERSHIP AND IT HAPPENED--SAME ROUTE, A CERTIFIED GROUP TAKES THE MOTOR OUT--GETS ANOTHER AND I SEND THE BILL IN FOR REIMBURSEMENT? GM DID ME WRONG AND WILL NOT EVEN HELP ME WITH A NEW BLOCK OR HEADS :bmad: :mah:
I HAVE BOUGHT FROM GM SEVERAL NEW CARS IN THE PAST 12 YEARS--NO MORE FOR ME.. VERY FRUSTRATED--THIS WAS A GM PROBLEM- NOT A OUT OF MY POCKET PROBLEM--ENGINE WAS NEVER OPENED UP BEFORE THIS. ANY IDEAS? sorry for yelling.Dave
Old Nov 30, 2004 | 03:48 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Generally I believe GM has to do the work for the warranty to apply. That's probably not uncommon for all car manufacturers. I'm sure that simply handing them busted parts will void every warranty out there.
My own dealer has told me about people heavily modifying their engines, blowing them up in races then swapping back to stock parts to try to enforce the warranty.
I'm sorry you've had such a problem, but it seems like there would have been one dealership within 1,100 miles you could have used to at least have the engine checked out.
Old Nov 30, 2004 | 03:55 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Should have put it back together & had the dealer take i apart...I'd fight it...I'm having them warranty shocks that I bought aftermarket for my Duramax. The tech said there was nothing wrong with them...I bought new ones elsewhere...took the worn out chit back to the dealer & made a seen...they are reimbursing me. Good luck.
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Sorry to see your problems hopefully you get it fixed!
Old Nov 30, 2004 | 04:05 PM
Avanti's Avatar
Avanti
You didn't check BEFORE pulling the engine? Was that to get around what your name implies, i.e. you've turboed the thing? If correct, of course they'd never have warranteed it anyway.
High-performance turns money into noise. Pull out the checkbook!
Lager99: The cost difference between shocks and an engine is how much?
Old Nov 30, 2004 | 04:10 PM
georgec114's Avatar
georgec114
I'm sorry for your loss....BUT, you have a car that won't run and with
your motor "broken," and you pay to ship it 1100 miles just because
you don't trust your local dealer?
What were you afraid of?
What experience did you have with them that would make you do this?
All this talk about dealers on the Forum makes people paranoid.
It's irrational behaviour.
So what's the cost to you after the shipping, the aggravation
and now the possibility of you paying for a new motor?
Maybe you'll have to lawyer up and go through that process.
And at what cost?
You showed them.
...George
Old Nov 30, 2004 | 04:13 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
me thinks there is more to this story...
Old Nov 30, 2004 | 04:17 PM
GrayC5's Avatar
GrayC5
Sorry to hear about your bad luck, but have you read the terms of your GM warranty? Looks like you might not have much recourse unless the repair facility you shipped the car to is an authorized GM dealer. Also, from what I've seen, the GM warranty is not that much different from the warranties of other car manufacturers. However, I do wish you the best of luck in getting everything resolved to your satisfaction.
Old Nov 30, 2004 | 04:18 PM
Tom73's Avatar
Tom73
From the Public Profile: 2003 EB Z06 A&A Ati Procharger/single frontmount intercooler 7 or 10 lbs/tpis headers/random tech xpipe,cats over 500rwhp
To me this is why they will not warranty the engine.
tom...
Old Nov 30, 2004 | 04:20 PM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
Old Nov 30, 2004 | 04:25 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Why aren't you telling the truth?
Why should all the other forum members pay for the consequences of modifying your perfectly good Z06.
Old Nov 30, 2004 | 04:26 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Hmmmmmmmmmmmmmmmmm. This was his 10/21/04 post on something that seems similar....
"I have to redo the motor in my car..I thought it was # 7 but it turns out my cam bolts came out and destructed the entire engine..I am putting a forged bottom end back in the car..I want it to last..So how many have run a blown 382? I have seen question about rod length/angle that makes it seem as not good for longevity..So I want a steel crank--and mine as well stroke it so it is practical..But who knows about how long it will live--shorter lifespan than 346 or just a myth? If properly balanced-blueprinted last just as long? drawbacks?"
And now a month later GM is the bad guy??????
Old Nov 30, 2004 | 04:28 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I've got to agree.
You state yourself that your vehicle has: 2003 EB Z06 A&A Ati Procharger/single frontmount intercooler 7 or 10 lbs/tpis headers/random tech xpipe,cats over 500rwhp THANK YOU ANDY!!!!!
Have you notified Andy! He should of advised you to remove the Procharger, bringing the car back to stock and take it to a dealer.
Sorry to hear about your misfortune, but some times we just look for trouble.
Old Nov 30, 2004 | 04:30 PM
bsmith's Avatar
bsmith
tom...
saw that...
might explain why he had to ship the car 1100 miles to get it worked on. Had to make sure the car wasnt recognized by anyone at the local dealers?????
Old Nov 30, 2004 | 05:03 PM
QuikZilver's Avatar
QuikZilver
If this is true, then I am sorry, but I don't feel sorry for you. GM covers their stuff from their defects. If you have had someone put other stuff on (AKA: Supercharger!), then you should go back to that company. How is it GM's fault that you added a bunch of boost to the motor, wasted the motor, and now want GM to fix it! I am sorry, but the attitude that you have in the first post here is totally misplaced. I feel for your loss. More power costs money and reliability. Looks like the reliability caught up to you...now more money out of your pocket.
I have been very happy with the reliability of my Z and even though my dealer isn't the sharpest tool in the shed, I still take it to them for warranty work. What is the worst case? They break something else and they have to pay for it.
Good Luck!
Old Nov 30, 2004 | 05:07 PM
IllinoisCorvette's Avatar
IllinoisCorvette
Its GMs Problem if the motor is run as stock. Heavily modified its your bill im afraid. This reminds me of someone in the C6 section that is taking his C6 apart bit by bit to find a rattle instead of taking it to the Dealer, its just nonsense if the car is under warranty. Someone here in Chicago had an aftermarket air intake installed, and in a heavy rain the motor sucked water in and blew the motor. GM also nixed that claim because aftermarket parts were installed.
Old Nov 30, 2004 | 05:14 PM
Sorry to hear this, but if you truly have the mods listed in your signature, then I can understand why GM said no to the warranty. It is clearly spelled out in the warranty terms that modifications are not covered. Don't blame GM for this one. Hope somehow you get your car back together, but I think it will be at your expense.
To Gm Did Me Wrong
Old Nov 30, 2004 | 05:15 PM
Joe's Eray's Avatar
Joe's Eray
Looks like this is going to have to come out of your own pocket Dave. No use even trying to fight GM if your car was SC'd. Be better off in putting a 383 or something like that in the car.
Old Nov 30, 2004 | 08:16 PM
m1k3's Avatar
m1k3
saw that...
He must live in the same area as the dude whose column locked up and so he floored it and wrecked his car.
Old Nov 30, 2004 | 09:11 PM
WhiteC5Vette's Avatar
WhiteC5Vette
GM is not to blame, and since GM has legal people reading this site, as well as almost all other sites that discuss GM, you can bet, this has been noted.
