Lower my car?
Old Dec 3, 2004 | 12:56 PM
BILL RUPP's Avatar
BILL RUPP
Default Lower my car?
I read a a lot of threads here where members show pictures of their rides with new wheels, mods etc. The responses are usually positve but will many times include " lower that car" or "needs to be lowered". These same members will jump all over some mods for being too ricer. Isn't slamming a car about the first thing ricer owners do? Having said that, I like the slightly lowered look on Vettes. I'd like to know from lowered owners, what problems lowering has caused you. For instance, I'm stock height and still can't back out of my steep driveway without scraping my front spoiler. I want to lower but I'm worried about the resulting damage. Should I be?
Old Dec 3, 2004 | 01:05 PM
Patches's Avatar
Patches
Stock height on the production C5 was set on a worst-case, real-world basis. Ground clearance has to be set so the typical owner has no problem negotiating normal roadways and parking lots. That means a lot of us are going to be dissatisfied with the ride height, and thus, the stance of the car. Looks like a 4x4. The handling can also be improved by lowering the car's center of gravity. Using the height adjustment built into the suspension, you can easily stay within the suspension travel tolerances the car needs to remain streetable. Getting the wheels to look more neatly tucked into the wheel wells is just a few screw turns away.
Consider the pics of mine below and after lowering shortly after I brought it home.
Before - 4x4!!!
After
It just looks so much better and I can still get over most speed bumps and obstacles with no problem.
Old Dec 3, 2004 | 01:12 PM
VetteSiNz's Avatar
VetteSiNz
I'm going to lower mine same time when I install new sway bar/shocks, drilled rotors and paint the caliper. Still learning everyday.
Old Dec 3, 2004 | 01:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I don't mean to hijack the thread, and along the same lines, I have a question...
A buddy of mine has an '03 Coupe with F55, and I've been on him for nearly a year about getting rid of the off-road look!
Has there been any definitive answer as to whether lowering is bad or okay with F55? Has anyone else lowered their car with the F55, and then how much? He's not considering cutting the bushing or dropping it into the weeds, just dropping the back about an 1 1/2", and the front about 3/4"......thanks!
Old Dec 3, 2004 | 01:38 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
I'm lowered as far as I can go on stock bolts without cutting the bushings. The only problem you may run into is the obvious....scraping. Remember, though, that the front spoiler is on a hinge and is meant to "give." The ride may be just a bit harsher also.
Old Dec 3, 2004 | 01:59 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Mine has been lowered as far as it will go without coil overs. Meaning no stops in the front and longer bolts in the back. I have about a finger and a half clearance between the tire and the 1/4 panel. I have not had any issues with this set up in a year and a half. I have scraped on a few speed bumps but nothing exsessive. The ride is a little stiff but you get used to it. Kaley
Old Dec 3, 2004 | 02:08 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
lowered with no regrets and I have the inclunded driveway. I've learned to approach it at a 45 degree angle and generally dont hear any scraping up front Lower it, it wont hurt it
Old Dec 3, 2004 | 02:24 PM
yellow viking's Avatar
yellow viking
Lower it all the way down on the stock bolts. This will take you down ~1", and will lower your CG, improve handling, braking, and aesthetics.
Combine this with a set of A&A's frame savers and rocker rails, $109 for both, and a must for lowered cars, to protect you from tire stops and inclined driveways. Also, consider adding a set of Bilstein sports shocks for ~$300 and a set of Z06 sway bars (~200) and you will have a very nice performing and looking C5. The front spoiler(s) can take a lot of abuse and it is not a big deal if they scrape. Remember to do an alignment if you lower it. Start by lowering it only and drive it for a couple hundred miles to see how you like it. You don't need to align it immediately. You can lower the car yourself or pay ~$100 to have it done.
Old Dec 3, 2004 | 02:29 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Mine is lowered on stock bolts, no cut bushings, Hotchkis sway bars, Bilstein shocks, Z51 springs, SS brake lines, and a partridge in a pear tree.
No problems. Road or track.
Old Dec 3, 2004 | 02:40 PM
MikeJamesC5's Avatar
MikeJamesC5
Black Sedan...I had the F45 suspension but I had that option deleted for about $80 by a Chevy Dealership. Then I installed the Bilstein Sport Shocks and Hotchkis sway bars and lowered it 1.5 inches. I still can go lower and probley will eventually.
I believe the F55 is the same thing almost as the F45 just the newer version. I've also been told that you don't have to delete it but it depends some people have problems if they don't. I just did because a forum tuner recommended it.
Cajun...How do you like your Z51 leaf springs? I'm debating on getting those or the Z06 ones.
Old Dec 3, 2004 | 03:23 PM
Dave68's Avatar
Dave68
I was against lowering for the longest time, but after seeing many lowered C5s and how much better they looked, I decided I HAD to try out the lowered look. You'll notice that the trend with most cars today is with minimal tire-to-fender gap. BMW seems to have started this design philosophy and many other manufacturers have folowed suite. My sig pic shows what lowering on the stock bolts will do.
Old Dec 3, 2004 | 03:35 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Lowering has been a popular hotrod mod since the 30's and 40's and is a trend that will likely never go away.
Sure the ricers do it too, but it was popular long before they were even born, so to call this a ricer mod is ridiculous.
With that said....Slam it!!
Old Dec 3, 2004 | 03:36 PM
NSTG8R's Avatar
NSTG8R
personally, i'd just upgrade to the z06 ones, Eventually I will. My Z51 is great but, it could be better.
seriously. I hate how if you do anything that even resembles a civic you get hit with the too ricey comment.
"whateva, whateva I'ma do what I want."
Old Dec 3, 2004 | 03:45 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
PM sent......
Old Dec 3, 2004 | 03:51 PM
BILL RUPP's Avatar
BILL RUPP
Ya'll have made my mind up for me. I just printed the lowering instructions form an old thread and I'm going to work on it this week-end. Thanks to all for your input.
Old Dec 3, 2004 | 03:54 PM
CDH76's Avatar
CDH76
LMAO!
Old Dec 3, 2004 | 04:29 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
No such thing as too low!!
Check out a member's car - ALLKAR. Now THAT is low!! I would love to get my car that low - and if I can't negotiate a entrance/street/state- I'll drive my DD there
Lowered to the max on stock bolts - now Inferno is *really* going d-o-w-n
To Lower my car?
Old Dec 13, 2004 | 03:16 PM
SMX's Avatar
SMX
Slam it!
Old Dec 13, 2004 | 03:27 PM
FNC80's Avatar
FNC80
This is lowered all the way in the rear and 1/3 of the bushings cut up front. Very aggressive stance and perfect, IMHO.
Good luck!
Old Dec 13, 2004 | 04:01 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Im lowered on stock bolts with F55. no problems!
