oil change question
Old Dec 9, 2004 | 12:50 PM
LH04's Avatar
LH04
Default oil change question
Hello, I was wondering how many of you are familiar with synthetic oil properties? Specificly Mobil1. I have a DD now so my 04' MSG does'nt travel much. My stealership is sending me threatening letters regarding my car being overdue for an oil change. The car reads 47% oil life remaining. Does the General support that reading as a guide for oil changes? If synthetic oil is so great would there be a time limit on its life as opposed to a milage reading? I don't want my factory warranty to become void. Thanks!
Old Dec 9, 2004 | 01:06 PM
If it is anything like most dealers, they send these form letters out based on the traditional 3 month, 3000 miles standard for conventional oil changes. With the synthetics, you do not have to change it that often unless you want to. I normally wait until my oil life shows about 40-45% on the DIC, then I change mine. That comes out to be about 4500 miles.
Old Dec 9, 2004 | 01:20 PM
ALLEGRO's Avatar
ALLEGRO
I change every 5K in the AE but go for 10K in my '98 Jimmy.
Old Dec 9, 2004 | 02:10 PM
mikestuff's Avatar
mikestuff
Check the owner's manual maintenance schedule to see what you have to do to maintain the warranty.
Old Dec 9, 2004 | 02:25 PM
jrose7004's Avatar
jrose7004
Thats what I would do!
Old Dec 9, 2004 | 02:41 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I would change at 5K unless I travelled less than that per year. I change my oil before the winter and then again in the spring. I really don't look at mileage as much as I look at time it has been sitting in the car (I put on about 8K per year).
My car sits all winter in the garage so I feel that fresh oil is best to eliminate the chance of any breakdown. In the spring I run the old oil for a bit, but then change it towards the later part so there is fresh oil for the summer.
Regarding your letters - I believe they are just notification letters. If they are not paying for the oil change then you can go anywhere and they would still send you letters. Of course I would verify with your warranty book to see if there are any guidelines that must be followed in order not to void it. If there are then I would save all receipts stating when you had the oil changed...
Old Dec 9, 2004 | 03:02 PM
Dave68's Avatar
Dave68
Go by the D.I.C. or 12 months, whichever occurs first.The Mobil 1 that is used in many C5s has been proven to last 12,000 miles with no filter change (although 2-3 quarts were added during this time interval), so I would not worry about going more than 5000 miles as long as you follow the rule listed above.
I change my oil once per year.
Old Dec 9, 2004 | 03:49 PM
Corvette00Car's Avatar
Corvette00Car
I take it out of my car and put it in my son's klunker. He gets free synthetic oil that is only half used.
Old Dec 9, 2004 | 05:00 PM
Tom/99's Avatar
Tom/99
My first oil change was at 2,800 miles, the DIC showed 81%. The second oil change was at 5,100 miles, and the DIC showed 77%. I plan on changing the oil on this car every 2,500 miles. All my other cars go 2,000 miles between changes. To me, it's cheap insurance.
Old Dec 9, 2004 | 05:19 PM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
cool
Old Dec 9, 2004 | 06:02 PM
JC in XTC5's Avatar
JC in XTC5
The DIC oil life algorithm is somewhat conservative (except for dusty conditions). As per the manual, DIC or 12 months.
Old Dec 9, 2004 | 06:24 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
GM wants you to follow the oil life gage in the car, except for the one-year change if the car is not driven that much. The gage is more accurate than most people believe, but I have seen the testing documentation on the use of the gage or an oil change light, and it is quite impressive.
I have had two oil analysis performed on my Mobil 1. First oil change was done at 5800+ miles and the oil was in excellent condition. Second oil change was done with 6200+ miles on the oil, and the oil was in very good condition. The TBN was still high on both of the reports. If you are running a K&N or similar type filter, you might want to change around 20 percent due to the increased amount of dirt a K&N type filter allows into the engine. However, if running a paper filter, go for about 10 percent.
Dealers and oil change places are in the business to change oil and make money.
Old Dec 9, 2004 | 06:29 PM
red97vette's Avatar
red97vette
the Mobile1 with the K&N filter is proven to run 20,000 miles without any problems at all. Infact, i saw a review where they changed the oil on a regular car every 3,000 miles, and then with the synthetic oil and special filter, the one oil change at 20,000 miles did less wear to the engine than changing a regualr cars oil every 3,000 miles.
I drive my vette all the time, I run Mobile1 with the K&N, changed the oil at 9,000 - 10,000 mile mark, oil looked (golden) brown (still not totally black), and I didnt burn more than half a quart, with no need to refill inbetween. I know many of you guys might say that the oil looses its viscosity/strenght even though it looks nice...but they run that oil to 30,000 miles on test cars before signs of wear in the oil itself become bad.
just my .02
red
Old Dec 9, 2004 | 06:30 PM
Bill Dearborn's Avatar
Bill Dearborn
You can get a cheap $1M Life Insurance policy if its payout is dependent on you being trampled to death in the middle of a Buffalo Stampede at the South Pole.
Sometimes you just do not need to do some things.
I run my car in several DEs per year and put about 4K miles on per year. I change the oil once per year. I just changed it last week which was one year to the day from the previous time and the oil life indicator was at 15%.
Bill
Old Dec 9, 2004 | 06:34 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
just my .02
red
Mines not a daily drive so I stick to the 12 month rule. I never even get close to 0% on the DIC.
Old Dec 9, 2004 | 07:06 PM
HalM's Avatar
HalM
Most of the synthetic oil mfrs including the high end guys (Redline, Amsoil, etc.) recommend at least changing the oil once a year. I'm sure you could go longer but then you really should go on a sampling/analysis program to establish the integrity of the oil as a function of time. I'm guessing two years wouldn't be out of the question. Depends a lot on what the miles were like. If the few miles you did drive during the time interval were freeway miles where the oil came up to full temperature and had a chance to boil off moisture and volatiles then ok. If it was short trips to the store then I would stick with once a year.
Old Dec 9, 2004 | 07:41 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
I change mine when ever I need a few hours away from the wife and kids It's worth the $40 for the few hours of piece and quite.
Peace
Willfulone
To oil change question
Old Dec 9, 2004 | 08:58 PM
GrayC5's Avatar
GrayC5
Follow your owner's manual and forget the dealership. Everything will be fine. Change engine oil and filter as indicated by the Engine Oil Life System or every 12 months, whichever occurs first. The GM Service Manual reads much the same.
Old Dec 9, 2004 | 10:24 PM
6 speed Sid's Avatar
6 speed Sid
Forget the dealership, the folks here know best. I change twice a year since I only put about 7K per yr on the clock. Only once a year would be ok, It just makes me feel good to change the oil.
Old Dec 10, 2004 | 12:06 AM
gpotski's Avatar
gpotski
Good idea
