TPS retrain
Old Dec 11, 2004 | 11:16 AM
mikestuff's Avatar
mikestuff
Default TPS retrain
I had a left rear TPS go dead, so I ordered and installed a new one. Went to retrain TPS and the left front and right front were fine. Can't get the right rear to retrain now and it worked before. Any thoughts short of replacing the right rear TPS?
Old Dec 11, 2004 | 12:41 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
1. Make sure you're getting the magnet in the same position as the others.
2. Battery dead in that TPS?
Old Dec 11, 2004 | 12:49 PM
Your magnet must be strong enough or the others wouldn't work. Could be that the one sensor has gone bad also. I'd try to retrain all four again and if that doesn't work, it may be time to replace the right rear sensor.
Old Dec 11, 2004 | 12:55 PM
mikestuff's Avatar
mikestuff
This one worked until I replaced the other one. Maybe the battery is just weak in it. I guess I'll go with the replacement.
Old Dec 11, 2004 | 12:58 PM
MyVetteDream
I hate it when that happens. Sorry about your troubles.
Old Dec 11, 2004 | 01:08 PM
DAYCRZ's Avatar
DAYCRZ
Try it again, I had trouble with the right rear,had to start over then had trouble with left rear
Old Dec 11, 2004 | 01:17 PM
ooh yeah's Avatar
ooh yeah
I put a different set of wheels and tires on for a autox event and now I can't get the back right one to beep either I know the darn things were working when I removed them.
Old Dec 11, 2004 | 01:48 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Have you tried moving the magnet completely around the valve stem (just a thought)?
Old Dec 11, 2004 | 02:10 PM
mikestuff's Avatar
mikestuff
I've tried it 2 or 3 times with all the possible combinations I could think of for magnet position. It's more aggravating than anything. I just don't like having to hit the reset button the clear the "Service Tire Monitering System" message each time I drive the car.
Old Dec 11, 2004 | 02:59 PM
billiardcue's Avatar
billiardcue
Try driving the car 20 - 30 miles to heat up the tires and try again.
I have three sets of wheels and tires and change them frequently, when it is cold outside one or two of my sensors will not relearn until I warm them up.
Sometimes you have to hold the magnet for 30 seconds or more for the horn to beep - patience is a virtue.
Old Dec 11, 2004 | 03:32 PM
mikestuff's Avatar
mikestuff
I'll give it a try! Thanks.
Old Dec 11, 2004 | 07:15 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Warm 'em up, especially if they have been sitting for a while.
To TPS retrain
