When parking Your MN6
Dec 11, 2004 | 06:55 PM
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
When parking your MN6 on a level area, do you set the parking brake or just leave it in gear...1st or R...
Peace
Willfulone
Dec 11, 2004 | 06:57 PM
First gear, Parking brake on!
Mac
Dec 11, 2004 | 07:02 PM
Quote:
Mac
Dec 11, 2004 | 07:03 PM
Depends on the incline, but usually just in 1st or reverse
Dec 11, 2004 | 07:05 PM
Dec 11, 2004 | 07:08 PM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
1st gear, no brake on flat surface
Dec 11, 2004 | 07:13 PM
In 1st gear with the hand brake on.
Dec 11, 2004 | 07:14 PM
Both 1st gear with the parking brake on!
~MS
If I'm on a slope I put it in gear and use the brake, if in the garage (very flat) I just put it in Reverse so it's ready when it's time to leave!
Dec 11, 2004 | 07:18 PM
well that helps alot i usually put the hand brake on and on slopes put it in first
Dec 11, 2004 | 07:26 PM
Always use both. There's no reason not to.
Dope
Cruise-In VII Veteran
reverse, no E brake.
Dec 11, 2004 | 07:34 PM
On level surface reverse or first
Dec 11, 2004 | 08:26 PM
Wow, am I an oddball.
Under normal circumstances, I always leave the trans in neutral with the p brake on. If the car gets hit I don't want the motion/shock running through the engine. Only exception is after a run at the track with hot brakes. Then 1st and no brakes.
Dec 11, 2004 | 08:43 PM
From: Vette Doctors Performance RX450 - 466RWHP !!!
Originally I was leaving it in reverse with the E brake on. But after the first time starting it up and almost ramming the wall behind me,
I now leave it in first!
Dec 11, 2004 | 08:45 PM
I always set the parking brake. Just be sure that the brake is adjusted properly and that it will hold the car.
Dec 11, 2004 | 09:24 PM
Mostly everywhere I got around here is flat, mostly just user park brake
Dec 11, 2004 | 09:29 PM
I always use 1st and parking brake on.
Dec 11, 2004 | 09:30 PM
2017 C7 of the Year Finalist
St. Jude Contributor
1st, no brake. When in my garage, wheels chocked
Dec 11, 2004 | 09:51 PM
Mac
but out in da sticks, kinda crooked and backed in.
Save Da Wave
