T84 install
Old Dec 17, 2004 | 01:19 AM
towercontroller's Avatar
towercontroller
Default T84 install
Anyone have any hard times installing these lights? Cant seem to find what im looking for in the search engine. Looked at the DIY part and looks fairly simple.
Old Dec 17, 2004 | 01:28 AM
FiberglassFan's Avatar
FiberglassFan
I have some lamps on the way that should arrive shortly, so we will be doing the same job in the very new future. Instead of searching for the 'T' code, try 'Eurospec headlights'. There have been MANY discussions about this both on this forum and at www.c5forum.com
Best of luck,
Jennifer
Old Dec 17, 2004 | 10:25 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
they install exactly like the old ones come out.
just reverse your removal procedure.
Old Dec 17, 2004 | 03:59 PM
Mike04's Avatar
Mike04
This is a link to the instructions I used.
http://www.c5forum.com/diy/eurolights2.php
Old Dec 17, 2004 | 09:29 PM
towercontroller
Default Relays
Is it neccessary to replace the relays?
Old Dec 18, 2004 | 06:50 AM
towercontroller
Default Relays
I didnt get any relays with my lights. No one remembers if you need to change them. I printed out the instructions just need to know if i need to buy new relays or not and what kind
Old Dec 18, 2004 | 08:29 AM
RPOZ4Z's Avatar
RPOZ4Z
No, just remove the old plastic lenses and install the new glass ones.
Old Dec 18, 2004 | 12:20 PM
DeeGee's Avatar
DeeGee
You need the wiring harness with the relays if you want to install the hi wattage lights (135/90). if you go with the low power bulbs the stock wiring is OK.
To T84 install
