Trailering a C5
Old Dec 19, 2004 | 08:08 PM
AU N EGL's Avatar
AU N EGL
Originally Posted by Steve L
I put a axle strap thru the front skid bar .
Be carfull. I have seen bent A-arms from straps. resluting in ppl ratcheting the straps too tight on that A-arm
and cars fall off open car trailers when the strap was put a round the wheel and the pick-up and trailer slide off the road as a result of road debris and double right side tralier tires blowing out.
I think the t-hook and the #5000 each straps or better is the safest way to go with the double X tie down.
But it is your car.
Old Dec 19, 2004 | 08:19 PM
Steve L's Avatar
Steve L
But it is your car.
No , I don't use the a-arm , I use the front skib bar to winch it up and down . Then I use the t-hooks to strap down the car .
Old Dec 19, 2004 | 09:52 PM
AU N EGL's Avatar
AU N EGL
Old Dec 19, 2004 | 09:58 PM
RWhite's Avatar
RWhite
I also used two axle straps at the front and the rear. Worked great for the two years we trailered the 'Vette. Just check the straps for wear periodically.
Old Dec 19, 2004 | 10:16 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
What are you calling the skid bar?
Old Dec 19, 2004 | 10:32 PM
Steve L's Avatar
Steve L
In the nose of the car , I put the axle strap thru the skid bar and winch up the car . Then I use the J-hooks in the frame to strap the car down .
Old Dec 19, 2004 | 10:40 PM
VinR1's Avatar
VinR1
Originally Posted by Z06-JIM
I took AU N EGL's advise and use the T- Hooks & straps in an X configuration. Works great!
nice trailer! where did you purchase and how much??
also, is your car lowered and is there any clearance issues?
THANKS
Old Dec 19, 2004 | 11:19 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've put about 30k miles on my Z06 in the last two years... all on a trailer. Same method as AU N EGL describes above. Don't forget to take it out of gear once you get the straps on. You don't want it bumping around on the drivetrain the whole time.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
