I've tried the Hurst Shifter and do not like it. A shorter throw is not my objective. I'm mainly doing it for the height and whereas I have cut my stock as low as possible, the C6 shifter is lower and I get to retain the nice smooth feel.
I hear you and I have heard that from so many others. I guess I have been very lucky that my Hurst has never made any noise and has worked flawlessly for 2 years now.
Mine is perfectly quiet and shifts smooth as silk.
Its not the noise although I have heard about this but there is a solution for that anyway.
To me the throw is just too short as is the Ripper. Would be great for the 1/4 mi but doesnt play a roll on a roadcourse. The stock is just fine, at least it is for me. I just dont like the height of the shifter, even after I cut it. If you take the *** off, the C5 Shifter is really tall!
I had the rattle problem but corrected it with Teflon Tape. Since it's been great and wouldn't have anything else. I hate the wander wands that just slop all over the place. My .02 Merry Christmas.
I know it has been brought up before but what was the final answer? Could it be done?
I asked this question an got an answer a while ago.. The answer is YES it is a direct fit.. I got that answer from Ernie directly at Breathless Performance.
The shifter may be a direct fit on a C5, BUT that doesn't mean it will be an improvement nor will it shift like a C6. The C6 also changed some internal linkage in the transmission to make it shift better.
The point is that the C6 is a SHORT shifter and it's STOCK.. So one should benefit from short throws from a quiet stock shifter.. There should be a bunch of them hitting the used market soon as they are replaced with the Rippers and Hurst, Etc....
Noone ever said it would shift like a C6. And noone should expect it to.
Its the height of the shifter that is attractive while being able to maintain the same C5 mechanical throw. I bet you'll see lots of C5 owners switching once they find out it works.
I cant wait. Good job Chuckster BTW, do you have the GM Part #? Want to see how much GMPARTS DIRECT is selling them for now if they in fact offer them.
