STP fuel cleaner
Old Dec 23, 2004 | 02:16 AM
DrValidus's Avatar
DrValidus
Default STP fuel cleaner
Any comments, suggestions, recommedations, stories regarding bottled fuel system cleaner agents. (I just bought the $13 STP fuel system cleaner but have not poured the bottle into my gas tank yet)
Happy Holidays everyone!
Old Dec 23, 2004 | 08:09 AM
ronwc's Avatar
ronwc
It may work fine but most use Techron -
Old Dec 23, 2004 | 08:10 AM
ooh yeah's Avatar
ooh yeah
Techron is the way to go.
Old Dec 23, 2004 | 08:14 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
$6-7 at Wal-Mart,same stuff that GM sells over the counter for $18
Old Dec 23, 2004 | 08:23 AM
C6~Missle's Avatar
C6~Missle
Use Redline FI cleaner.. This stuff is VERY safe and is not solvent based. Some of these FI cleaners contain harsh solvents that can attack rubber seals over time. Redline is based on detergents which are not harmful to sensitive parts.
mike
Old Dec 23, 2004 | 08:46 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Listen to this Guy cause he knows his stuff.....
Old Dec 23, 2004 | 09:01 AM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Use a top-tier gasoline and save your money. Just my .02.
http://www.toptiergas.com/
Old Dec 23, 2004 | 09:26 AM
jrose7004's Avatar
jrose7004
I always use Berrymans!
Old Dec 23, 2004 | 11:49 AM
XCESIVE's Avatar
XCESIVE
the best i've ever used is K44 by BG products....love it!!
Josh
Old Dec 23, 2004 | 12:51 PM
It won't hurt the system and will work, but the Techron works better.
Old Dec 23, 2004 | 01:06 PM
JC in XTC5's Avatar
JC in XTC5
mike
Redline Complete Fuel System Cleaner here. Have used it occasionally over the past 4 years. Safe for all parts including O2 sensors.
Old Dec 23, 2004 | 01:13 PM
Cruncher's Avatar
Cruncher
By using a top-tier gasoline like Chevron or Texaco, there is no need to use a fuel cleaner. Chevron and Texaco gasolines have proven that they can remove deposits left behind by other gasolines. Your owner's manual specifically states not to use additives.........they will destroy your injectors, your seals, and destroy everything in between......
DrValidus's Avatar
DrValidus
Thanks! I will use this one since I already have it. I will definitely get Techron the next time.
Old Dec 23, 2004 | 01:18 PM
Cruncher's Avatar
Cruncher
How did Shell become a 'top-tier' gasoline??? Shell has a documented history of having a high sulfur content which will eat away your fuel sensor contacts. Anyways, did you notice that Shell gasolines always cost more than all other brands........I figure that is to offset their "rebates" from their credit cards....some rebate/some rip-off.
Old Dec 23, 2004 | 01:23 PM
Cruncher's Avatar
Cruncher
For Chevron to work, you need more than one tank. Both Chevron and Texaco gasolines use Techron and have shown that deposits are cleaned after 5 tankfuls of gasoline. You can't just use it once. If you continously use Chevron or Texaco gasolines, there is no need to spend extra money or to use the Techron additive which can be separtely purchased. I would only buy the additive if for some reason I had to use a few tanks of non top tier gasoline...there is no other reason to purchase the additive if you are using Chevron or Texaco since the gasoline already contains Techron.
Old Dec 23, 2004 | 01:37 PM
bpc4me's Avatar
bpc4me
how often do you guys use this stuff?
Old Dec 23, 2004 | 01:49 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I use Redline S1 fuel system cleaner..no problems
To STP fuel cleaner
