First time jacker!!!!!!!!!
Old Jan 12, 2005 | 01:32 PM
YBNORML's Avatar
YBNORML
Default First time jacker!!!!!!!!!
What capacity hydraulic floor jack should I use if I want to lift my C5 using the cross members? Wal-Mart has an aluminum one that's nice and light but it's only 1 1/2 ton. Do you think it's safe? Also, any suggestions on jack stands and jacking points? Thanks in advance for the feedback.
Old Jan 12, 2005 | 01:36 PM
TruUndrtkr's Avatar
TruUndrtkr
maybe i should have ask'd that question b4 i purchased a jack on sale 4 $30 (regluar $79) from a local auto parts store...the jack gave out and the car almost fell on me.. :o
Old Jan 12, 2005 | 01:38 PM
ALLEGRO's Avatar
ALLEGRO
One and a half tons is equivelent to 3,000 lbs. Our whole car only weighs about 3,300 lbs.
As long as the jack is of quality it should be just fine.
RULE # 1
Always use jack stands when elevating a vehicle
Old Jan 12, 2005 | 01:44 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
RULE # 1
I agree, use jack stands !!!!!!!!!!!!!!!
Will send pics this afternoon if some of these guys don't
Old Jan 12, 2005 | 02:03 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
1 1/2 ton jack is fine - ALWAYS use jack stands though as everyone else has said - ANY hack can have a failure regardless or weight rating.
Old Jan 12, 2005 | 02:11 PM
vetteship's Avatar
vetteship
Jack stands is a must. Also make sure you don't damage the botom sill lifting the car, extra care should be taking when lifting the C5's.
Old Jan 12, 2005 | 02:12 PM
DaBoz's Avatar
DaBoz
I believe this is ONE time when "Bigger Is Better"... I've a 2 ton jack from Sears, cost $175. Worth the price. Oh, and yes, I use jack stands.
Old Jan 12, 2005 | 04:06 PM
Dave68's Avatar
Dave68
I have a $50 2-ton and never once got under the car without having jack stands in-place. Jacks are designed with a built-in safety factor but regardless, use stands or ramps if you need to go underneath.
Old Jan 12, 2005 | 04:31 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I have to add my spin on the topic..
"Just Don't go blind"
Old Jan 12, 2005 | 04:33 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Great minds think alike - is that hair on my palms....
Old Jan 12, 2005 | 05:27 PM
1.5 ton should be fine, but I have a 2 ton floor jack that I use. A little extra can't hurt. I always use jack stands though to be sure it doesn't fall.
Old Jan 12, 2005 | 05:33 PM
YBNORML's Avatar
YBNORML
Thanks for the input everyone. I don't think I was clear enough. I will absolutly use jack stands, just wondered what capacity and where to put them. I think I will buy a larger jack. Thanks again.
By the way ET, my arm is killing me!!!
[IMG][/IMG]
Old Jan 12, 2005 | 06:17 PM
Jeff Deal's Avatar
Jeff Deal
I used a hockey puck and the spare tire jack from my neon on one of the sides. Once I got it snugged up, I used an air gun to turn the bolt on the jack. No sore arms! It was the only jack that I owned that was low enough!
I was only doing brakes, and had no intention getting under the car....
Old Jan 12, 2005 | 06:23 PM
stamford52's Avatar
stamford52
Default Jack stand
Does anyone have any pictures that shows how to jack (location) car up.
Where jack goes and how to use hockey pucks.
1st time corvette owner.
Joe
Old Jan 12, 2005 | 07:44 PM
VetteSiNz's Avatar
VetteSiNz
Joe
Try this site.... very informative. http://97vette.com/howto/carlift/index.html
Old Jan 12, 2005 | 09:29 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I just bought the jack you are talking about. I've only used it once but jacked the front up and put rhino ramps underneath the wheels. Not a bad looking jack, but as with all jacks safety first. I thought about a better one like the Sears, but all I really bought it for was oil changes.
Old Jan 12, 2005 | 10:02 PM
Tim04C5's Avatar
Tim04C5
Here's another site you can check out,
http://www.idavette.net/hib/C5diy/c5diy1.htm
To First time jacker!!!!!!!!!
