[Z06] Different Shifter?
Old Jan 13, 2005 | 10:04 AM
'04 Z06 DFW's Avatar
'04 Z06 DFW
5th Gear
Default Different Shifter?
Anyone tried a different shifter than the stock Z shifter? Mine seems not only longer throw than it should have, but also not very smooth.
Comments?
Old Jan 13, 2005 | 10:25 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Comments?
Just do a search on shifters & I'm sure you'll be reading for hours...
Ron
Old Jan 13, 2005 | 03:34 PM
dvandentop's Avatar
dvandentop
i like my stock one just fine.
i did love pro 5.0 in my 95 t/a
Old Jan 13, 2005 | 05:57 PM
SoulDad570's Avatar
SoulDad570
Comments?
This is probably the most popular thread topic
I switched to the Hurst Billet shifter and I love it. But, it's a mixed bag.
- The good: Fast and precise shifting!!
- The bad: Noisy
If you like a quiet ride (as if the Z06 is quite ) more than a precise shifter, stick with stock.
Ciao,
Rick D.
Old Jan 14, 2005 | 08:31 PM
RICHARD D. HUDSON SR's Avatar
I Have The Hurst/plus Billet On My 01 Sw-wht
To Busy Listening To Sweet Rpm's To Hear Shifter Noise
Old Jan 14, 2005 | 08:38 PM
Hercdriver's Avatar
Hercdriver
Do the Hurst!! It's great!!
Old Jan 14, 2005 | 09:02 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I have the B & M Ripper Shifter and love it!
Old Jan 14, 2005 | 09:16 PM
Vettez16's Avatar
Vettez16
Default Like The Car!
Real Sharp Brother! Oh I have the B & M Shifter Less noise than the Hurst, But The Hurst May Have A slightly less throw. Just an opinion from driving two similiar cars. In either case past post have alot of info on this subject. Might want to check it out.
Old Jan 14, 2005 | 10:48 PM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
I recently installed the Breathless Performance shifter and really like it. There is a great article over on Z06vette.com by a guy who had a B&M and switched to the BPP. He states that the BPP is better than the ripper...this is, of course, subjective for each person.
I love my new shifter and couldn't go back to stock after experiencing the precision shifting of the new one. There will be an increase in internal noise/vibration with any of the aftermarket shifters, but the tradeoff is worth it to me. The increase in noise is insignificant to me.
Another thing I like about the BPP is that it offers adjustability which the Ripper and Hurst do not. That can be a big factor when setting up the fit and reach of the new shifter. My new shifter allows me to keep my seat back a bit further because 1st is now where N used to be with the stock shifter...a big difference!
Good luck with your choice, but do at least check the BPP shifter out before you make a final decision.
Old Jan 15, 2005 | 09:39 AM
Z06 USA's Avatar
Z06 USA
Cruising
I got the Hurst and like many thought the shifting was too stiff at first but now can't imagine driving without it. I'm not sure if it loosened up or I got used to it or both.
Old Jan 15, 2005 | 09:41 AM
Morzoff's Avatar
Morzoff
I installed the B&M and love it
Old Jan 15, 2005 | 01:35 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Hurst here. I used the Hurst classic white billard ball **** for the C5 vette. It is a little larger and heavier than a standard classic. No noise or vibration at all. I power shift at 5500/6500rpm and haven't missed a shift yet, know I can't say that about the stock shifter. Also, the hurst has adjustable springs so you can adjust tension how you like. I used the heavy inner and lighter outer springs (each side). One thru four is like a knife thru butter, but hitting fifth/sixth is a little harder because of the progressive nature of the springs. However, if it's to hard shifting you can always put in light/light springs and also back off the tension set screws.
Old Jan 15, 2005 | 11:52 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
'04 Z06 DFW:
Dallas area here too....
I got a short shifter boot from vette essentials.
I cut my own shifter down over an inch.
It looks stock, and no issues with aftermarket shifters like I often here on here.
It felt like a night and day difference !!!! It is so easy to hit the gears more accurately now.
And its free ! (only cost is short shifter boot)
Toque
Old Jan 16, 2005 | 12:12 AM
DsC5's Avatar
DsC5
Old Jan 16, 2005 | 01:16 AM
Sho-nuff's Avatar
Sho-nuff
From: When I say who is the masta you gotsta say Shonuff
My wife hates the Ripper.
That's how great it is.
Old Jan 17, 2005 | 10:42 PM
Pilot135R's Avatar
Pilot135R
The Hurst is outstanding and after a week or two, you can't imagine not owning one. It was my favorite mod on my first Vette. Stock feels loose after you make the switch.
Old Jan 17, 2005 | 11:45 PM
jimmy2004's Avatar
jimmy2004
has anyone tried replacing the stock shifter w/ the new C6 shifter?
Old Jan 18, 2005 | 01:30 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have one from Kirban. I really like it. It is very smooth, and accurate and feels nice and tight.
I also changed my trans fluid to Mobil Synthitic ATF! That made a big difference.
Here is a picture of the shifter:
New Shift ****!
Bill C
To Different Shifter?
