Bilstein vs stock comparo
Old Jan 15, 2005 | 11:26 PM
88sk's Avatar
88sk
Default Bilstein vs stock comparo
I have stock springs& zo-6 sways&end links& kumho(non-runflats) ,off the car,the stock shocks look puny next to the bilstein sports ,pushing down on floor (compression)the bilstein require a little more effort to compress,the stockers rebound almost twice as fast as the bilsteins,on the car very noticeable change much firmer but smooth(its a perfect medium)a spring change would probably be too stiff & more for autox or track,overall I like it way better than the floaty(scary at speed) caddy stock ride.
Old Jan 15, 2005 | 11:30 PM
yellow viking's Avatar
yellow viking
Bilsteins are the best shock for the money and are great for lowered cars.
Old Jan 15, 2005 | 11:54 PM
Dave68's Avatar
Dave68
Do you have the Z51 option components? I wouldn't call my ride floaty (I have the Z51 option), but I wouldn't mind having a liiiiitle bit better rebound when traversing wavy corners.
Old Jan 16, 2005 | 12:29 AM
88sk's Avatar
88sk
dont have z-51,dont think that option is floaty compared to my stock (standard) is what I was comparing it to,be interested how the ride is w/z-51(or zo-6)option& bilstein sports,I reached what feels to be the happy medium which is firm-smooth& not firm-harsh,I got my current setup as per recommendations from members here & I like it& is far as I wanna go.
Old Jan 16, 2005 | 12:52 AM
Dave68's Avatar
Dave68
The Bistein research facility is 20 minutes away, so before I buy shocks, I may attend one of their free plant tours. I had Bilsteins in my 68 and they were fantastic. Build quality is unsurpassed, IMO.
Old Jan 16, 2005 | 03:44 AM
FiberglassFan's Avatar
FiberglassFan
And your new Bilsteins can be reconditioned at some time in the distant future when they need it
Jennifer .....With a new set of Bilstein Sports sitting here, just itching to get installed.
Save the wave
Old Jan 16, 2005 | 05:12 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I've got Bilsteins on a lowered Z51 suspension with Hotchkis swaybars.
It's certainly no "caddy" ride and doesn't "float".
Old Jan 16, 2005 | 07:12 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Does the car have to be lowered to be able to use Bilsteins?
Old Jan 16, 2005 | 12:54 PM
88sk's Avatar
88sk
NO,mine is stock height.
Old Jan 16, 2005 | 10:29 PM
65midyrowner's Avatar
65midyrowner
Cruise-In VIII Veteran
Default Difficulty on changeout
I changed a friend's frt shocks on his '99 Coupe. He wanted Bilstens instead of the factory shocks. I had trouble compressing the Bilstens so I wrapped a clothing belt around the shock then slipped the shock in the tight space and unhooked the belt. I had trouble compressing the factory shock; wound up using the belt again to remove it from the car.
To Bilstein vs stock comparo
