Halltech Stinger report
bxblkvert,
The HP increase from a cat-back is very minimal on a mildly-modded C5, so almost all the gains I saw were from the intake mod. Generally-speaking, a cat-back's main purpose is for sound.
By the way, install instructions and the cold air mod can be found at:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave
Here's my review:Great looking intake, Huge filter, install was straight forward and very simple.
For some reason mine was rubbing on the hood liner pushing the hood up a little at the front. This doesn't really bother me.
First time I started the car after the install I could hear air going into the filter over my Borla Stingers. Love it.
Took the car for a drive and it didn't seem like there was any Seat of the pants difference. I also noted that the car seemed to be running rich since the install. I drove close to 100 miles and brought the car home. Later that night I decided to check to see if I had any codes (No SES light ever appeared) sure enough and regeatably I had two codes: Lean Bank one and Lean Bank two. I decide to go through the connections and tighten them all down again. Everything seemed to be seated properly and the clamps seemed to need a little tightening.
Fire the car back up after tightening everything up and the codes went away.
The next day I decide to go for another 100 mile ride out into the desert. Just to make sure that I didn't have any issues. I repeatedly checked for codes along the way and none poped up.
When I got home I decide to see what it looked like on EFI live. Start logging data and notice that my Long Term Fuel trims are steadily rising. They continued to rise all the way up to 25 %. I decide to check the connections again and then re log the data. Sure enough the LTFT's are still at + 25%.
Obviously, there is some sort of problem. I decide to put my Stock intake system back on and log with EFI Live. As soon as I start the car the LTFT's bottom out just about +0 at idle.
Very disappointing. I want this intake on the car! I'm all about more air but I won't risk dumping a bunch of fuel and washing out my rings. Especially on a car that has 8K on the clock.
What should I do?
What should I do?
I'll bet that Stingers throw codes more often than Blackwings because the Stingers out-flow the Blackwings, pushing the computer beyond its capability to correct the A/F ratio.
Just installed mine today. small but perceptable improvements. I am pleased. I had to fit a 1/8 inch vacuum line into the coupler that was not accounted for in the kit. It was originally in the side of the corrugated OEM coupler. I just used an sharp awl to punch a hole, stretched it bigger with a tapered punch shank, and then inseted the plastic fitting. All is fine..No codes. slightly better response.
Jennifer
Perhaps when I add a new exhaust, I might notice both mods more.
When do you all notice the performance differences? Normal driving, high revs, what?
