Can runflats be plugged?
Old Jan 18, 2005 | 09:42 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Can runflats be plugged?
A question was asked to me from a member about repairing runflats. If you get a hole in them, can they be plugged? (assuming it was a pluggable hole in a regular tire)
Anyone confirm this for sure?
Thanks in advance.
Mark
Old Jan 18, 2005 | 09:53 PM
99 vett babycar's Avatar
99 vett babycar
they can be pluged the same way a "normal" tire can be pluged ie. within the tread patern not the side wall. However when any tire is pluged it lowers it's speed rating so a Z rated tire, once pluged, is no longer a Z rated tire but something less. How much less? I have no idea but Ive had 2 run fats plug and ran them out without any problem.
Old Jan 18, 2005 | 09:57 PM
TX Steve T's Avatar
TX Steve T
I believe that Goodyear says they can be repaired by "trained" servicemen.
I had a flat (can a "run flat" go flat?) on the rear of one of the Prowlers a couple of years back. A local independent tire shop patched the hole and I have had not had a problem with it in the last 3,500 miles.
Old Jan 18, 2005 | 10:09 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I had two screws in the same tire within a week. I only had about 3 thousand miles on the car with the original run flats. I got the first screw , removed the tire, Pluged it externally, put iot back on and got another screw in the same tire a week later, I pluged that the same way and put 40,000 more miles on those tires without an issue. I tried to keep it under 160 after I patched the tire.
Old Jan 18, 2005 | 10:12 PM
loudsam's Avatar
loudsam
Default plugged tire
I plugged one of my runflats early in the morning on a freezing Kansas turnpike on my way from picking my car up in Dallas. I could hardly feel my hands they were getting so numb, but I've put 7,000 miles on the tire since then with no problems. Doubt that I would take it to a very high speed though, I've been up to over 100 mph on it without any problems.
Ventanaman's Avatar
Ventanaman
I had mine repaired at a Goodyear facility. $20. No problems 10K miles later.
Old Jan 18, 2005 | 10:14 PM
mhaber's Avatar
mhaber
I had Les Schwab fix my flat with a patch. They came out to the car, removed the tire, took it to their repair shop while I watched them fix the flat, rebalanced, drove back to the car and installed the flat; $27. Perfect, no problems 8K later.
Old Jan 18, 2005 | 10:16 PM
Jim2003's Avatar
Jim2003
I had a nail in my rear tire. The tire dealer said they do not like to plug tires any more since it can do more damage as they poke the tools into the tread. He dismounted the tire and did an internal patch. That was about 10,000 miles ago and it holds the pressure perfectly. My 2003 now has almost 18,000 on it. I plan to avoid any plugs in the future.
Old Jan 19, 2005 | 12:25 AM
vert_vette's Avatar
vert_vette
GM dealer would't plug or patch mine cause the nail was too close to the edge, but I plugged it and it seems fine....tire only had 7000 miles on it...didn't want to replace it. I dont drive over 110 mph.
Old Jan 19, 2005 | 02:18 AM
GrayC5's Avatar
GrayC5
Puncture Repairs the Right Way
Old Jan 19, 2005 | 06:48 AM
Yes, they can be plugged. Just be sure the repair facility uses the proper repair procedure and you should be able to get many more miles out of the tire. I've had several repaired in the past and they have worked just fine.
Old Jan 19, 2005 | 08:45 AM
vetdude's Avatar
vetdude
Tire center here in MD told me plugging is no longer used; a vulcanized patch is the only method to use to maintain the tire's integrity. I've had two tires repaired this way with no problems.
Old Jan 19, 2005 | 10:17 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Yes runflats can be pluged i had mine done at NTB national tire and battery and they did a great job.
Old Jan 19, 2005 | 10:39 AM
Dave68's Avatar
Dave68
This is not true according to Goodyear. An EMT can be plugged/patched once and still retain its factory speed rating. All bets are off if it is plugged an additional time, however.
Old Jan 19, 2005 | 11:14 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Why would you risk your Vette using a plug? Plugs should only be used as a last resort. And then only to get you to a tire shop. A internal patch is the only way these tires should be fixed.
I have a plug kit and a compresor in the back of my car. But only to get me off the road and to a tire shop.
Old Jan 19, 2005 | 11:20 AM
RoadReady's Avatar
RoadReady
I've had both types: the internal patch and the plug. Both worked fine. There is a new type plug which the dealership tire guy says actually bonds to the tire. He will not use the old type "sticky rope" type plugs.
Old Jan 19, 2005 | 11:33 AM
RoadReady's Avatar
RoadReady
To Can runflats be plugged?
