Car Exploded
Old Jan 25, 2005 | 09:58 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Originally Posted by stangkiller18
WOW, so sorry to see that! Hope to see you at the Rolex still!
Chris
I'll be at the Rolex for sure. Just not with the Vette.
Old Jan 25, 2005 | 10:02 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Default I'm confused
First you said bellhousing and then you said, "SHE downshifted". Is this a 6-speed or an A4 we're talking about?
Old Jan 25, 2005 | 10:03 AM
Spacecoast's Avatar
Spacecoast
Holy Smokes If you go with the LS6, you definitely need to get a better set of gears Do I hear 3:42's with a 3200 stall
Old Jan 25, 2005 | 10:04 AM
georgehafe's Avatar
georgehafe
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
That really stinks.. Hope its not to bad
Old Jan 25, 2005 | 10:05 AM
JACKAL0PE's Avatar
JACKAL0PE
Originally Posted by JeepTJ
Looks like the crank broke.
Oh, no, no, no.
Gawd! I hope that's not it...but it sounds like it is.
Old Jan 25, 2005 | 10:06 AM
JeepTJ's Avatar
JeepTJ
See picture. Not sure what else to call that part. She is a A4.
Old Jan 25, 2005 | 10:52 AM
Dope's Avatar
Dope
Resident moron
Flexplate and/or starter probably just broke. One probably broke the other.
I highly doubt the crank broke unless you've actually taken it apart and seen that.
Dope
Old Jan 25, 2005 | 11:00 AM
Boozman's Avatar
Boozman
That sucks
Old Jan 25, 2005 | 12:13 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Looks like the crank broke. Getting ready to put her on jack stands and pull that rubber cover that can be seen in the picture. That should give a better view of what happened. The flywheel does not look like were it should be.
Bob at Dragon's Breath Performance is pricing me a LS6.
SSTTOOOPPPP!!!!!!
This oppertunity can not be wasted.
What ever you do dont give the wife ANY reason to believe that it is anything but total destruction.
Now repeat after me..
"Honey, there is no way this motor can be fixed." But dont worry, I've got it all taken care of.
" I found a line on a "New" LS2 motor that will just drop right in." It will actually "SAVE" money in the long run. But first I also need to do a little work to the rear end and transmission so that doesnt break as well..
Old Jan 25, 2005 | 12:51 PM
mjallen40's Avatar
mjallen40
Wow, glad you made it home without injury. Hope you are back on the road soon.
Old Jan 25, 2005 | 02:08 PM
Spacecoast's Avatar
Spacecoast
Originally Posted by AMERICAN_HP
SSTTOOOPPPP!!!!!!
"It costs money, so we can save money"
Fred, we are here to help. So if your wife wants a second opinion, tell her to ask one of us
Old Jan 25, 2005 | 02:52 PM
Lemans Blue's Avatar
Lemans Blue
Man that really sucks, you are so screwed I would hate to be you.
But, I have some really good news... I just saved a bunch of money by switching my car insurance to Geico
Old Jan 25, 2005 | 03:07 PM
  #33
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Old Jan 25, 2005 | 03:11 PM
  #34
Lemans Blue
reallly I am sorry to hear about your bad luck, just try to put in some humor
Old Jan 25, 2005 | 07:03 PM
  #35
JeepTJ's Avatar
JeepTJ
Thanks Ramon, after getting her on the jack stands today. Looks like the flywheel exploded. Busted the head off the starter. And now there is a piece of Flywheel wedge between the flywheel and the bellhousing. That is what is keeping the engine from turning.
So I hope that's all that is wrong. But it still means that the engine was stalled by this piece of flywheel at WOT.
Old Jan 25, 2005 | 07:15 PM
  #36
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Looks like the flywheel exploded. But it still means that the engine was stalled by this piece of flywheel at WOT.
Yeow Why would the flywheel explode
You'd better check the block good where the chunk got wedged in there.
Man....GOOD LUCK
Old Jan 25, 2005 | 08:28 PM
  #37
USA-VET's Avatar
USA-VET
SSTTOOOPPPP!!!!!!
To Car Exploded
Old Jan 25, 2005 | 08:30 PM
  #38
batsallover's Avatar
batsallover
What are the possible causes for flywheel failure?
Old Jan 27, 2005 | 07:00 PM
  #39
C54DAZ's Avatar
C54DAZ
IMO it was the starter that started all this. Ive seen it befor on a friends a4! It in turn caused the flywheel to explode. Any of you a4 guys make sure you have the new starter design with the solid mount!!! The old design is hollow on the long bolt side the new design is solid aluminum on the long bolt side.
Old Jan 27, 2005 | 07:10 PM
  #40
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
geez...sorry you had the bad luck. Hope you can get fixed and back on the road
