C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
po343 code ?
Old Feb 10, 2008 | 05:16 PM
prostarjy's Avatar
prostarjy
Default po343 code ?
Anybody seen this code , cam position sensor high voltage !!
Old Feb 10, 2008 | 05:51 PM
RoadRebel's Avatar
RoadRebel
Yes, more than likely the cam sproket bolts are backing out. Better get it some attention asap.
Old Feb 10, 2008 | 06:39 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
good save!
Old Feb 10, 2008 | 06:53 PM
Chris Stewart's Avatar
Chris Stewart
I got that soon after getting boost. It seems to be a common downfall to boost on a stock motor. Have you recently installed yours?
Here's an old post from when I went thru this too. Thanks to Phil and the forum I fixed it in time!
not starting right and a P0343 code, what's up?
Old Feb 10, 2008 | 06:55 PM
Mike04's Avatar
Mike04
Had the same thing, all 3 cam bolts were loose.
Old Feb 10, 2008 | 07:12 PM
prostarjy's Avatar
prostarjy
procharger installed 4yrs. ago.
To po343 code ?
