C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Dyno and AF
Old Apr 6, 2013 | 04:18 PM
MacNH's Avatar
MacNH
St. Jude Donor '14-'15-'16-'17-'18-‘19
I believe in the Beer Fairy
Default Dyno and AF
So I brought my car to a local dyno tuner this afternoon for a couple of pulls. First time on the dyno. 2002 Coupe, Vararam, x-pipe and Corsa Indy exhaust. 328/353, not bad numbers but we noticed a couple of issues. AF ratio is really high at idle, and it shows what looks like as the knock sensor kicking in and retarding at about 4600 rpm. DIC is not showing any codes. Tuner suspected an air leak somewhere but could not find one. We pulled out and inspected the Vararam and cleaned the MAF. All looked good. He was unable to correct the AF with HPtuner. Tried everything, but could not change the AF. Please take a look at the chart and let me know your thoughts. I know little about tuning, so go easy.... ;^)
Thanks,
Mac
Old Apr 9, 2013 | 12:02 PM
alextz's Avatar
alextz
When he is tuning, he should be turning off the MAF anyway.
Its impossible to see what could be wrong without seeing hpt log files.
check plugs, wires, coils, grounds.
check fuel pressure
Are O2 sensors switching ok?
check vacuum at idle
stock injectors?
how much timing has been dialed in?
what kind of gas you using?
too many variables.
Old Apr 9, 2013 | 12:33 PM
MX621's Avatar
MX621
the dyno graph looks a smige lean, but not too terrible. n/a cars usually like 12.7-80'S afr under power. when u say lean how lean u talking?
Old Apr 9, 2013 | 01:35 PM
MacNH's Avatar
MacNH
The tuner was concerned with the high A/F at idle and the drop in RWHP & RWTQ at about 4600 rpms. He could not affect either and stopped the tune and reloaded my stock tune. I don't think he was very experienced with LSx's, as his shop was full of SC'd Mustangs.
Old Apr 9, 2013 | 04:08 PM
alextz's Avatar
alextz
whats the dyno pull look like with stock tune?
do you have stock injectors?
Old Apr 9, 2013 | 07:01 PM
MacNH's Avatar
MacNH
I wish I knew. This was the first time I've had the car on the Dyno. The chart I posted is with stock tune, Vararam, xpipe and Corsa Indys. Injectors are stock.
Old Apr 10, 2013 | 08:56 AM
edcmat-l1's Avatar
edcmat-l1
Ignore the wideband reading at idle. It's in closed loop and as long as the trims are fairly close that's all that matters. In all actuality, it's not lean or rich, it's stoich.
As for the knock retard, if you can't get it to go away, first thing to try is seafoaming the engine. If that doesn't work, just deaden the knock sensor sensitivity slightly.
Old Apr 10, 2013 | 10:12 AM
Alvin@PCMofNC's Avatar
Alvin@PCMofNC
Supporting Vendor
Where are you located at? The fueling is not very good at all according to the dyno sheet. Look at the scaling. There are points where it looks 14:1 and 12:1. Also the dip in the middle almost certainly is knock retard. You may have some underlying issues but a good tuner should be able to fix it no problem. If your local to us in NC please come see us. We will be glad to help get the car back on track.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Mail Order Tuning & Sales
704-307-4227
Old Apr 10, 2013 | 10:56 AM
MacNH's Avatar
MacNH
Thanks for all your replies. I'm in New England, so I'll be bringing my car to Slowhawk so that Don can do his magic.
MacNH
Old Apr 10, 2013 | 02:17 PM
alextz's Avatar
alextz
check easy stuff....plugs, wires.
o2 sensors could be bad too
Old Apr 11, 2013 | 08:04 PM
USA-1 HP's Avatar
USA-1 HP
I sent you a pm, I used the same tuner and was not impressed at all. I'm going to be using Slowhawk myself. I can't believe that he advertises as being a qualified tuner for these cars.
Old Apr 11, 2013 | 11:03 PM
MacNH's Avatar
MacNH
PM replied.
Old Apr 12, 2013 | 05:02 PM
GoatKart's Avatar
GoatKart
my .02 worth... Collect your car and run for the hills from that "tuner" if he doesn't understand the basics of even power enrichment tuning on a lsx motor, your asking for trouble...
Old Apr 13, 2013 | 09:08 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
As I said before. The tune should be pretty simple to correct. There are a few key spots to change with that intake on the car.When we are done there will be no knock and the A/F will be in check. Of course the numbers might be lower due to my Mustang dyno. LOL
Old Apr 13, 2013 | 09:17 PM
MacNH's Avatar
MacNH
Thanks Don. I'll see you in the next few weeks when my work calendar opens up.
MacNH
Old Apr 27, 2013 | 10:10 PM
MacNH's Avatar
MacNH
Spent this morning at Slowhawk. Feels like a new car! Thanks Don......
Old Apr 28, 2013 | 12:30 AM
Supercharged111's Avatar
Supercharged111
A motor's a motor, I don't get how someone could be good and Fords and not Chevies. You give 'em what they want, the dyno tells all. He probably sucks at tuning Fords too. Glad you got it sorted.
To Dyno and AF
Old Apr 28, 2013 | 02:06 PM
tacman's Avatar
tacman
St. Jude Donor '13
Default Tuning protocols
check fuel pressure
stock injectors?
too many variables.
Why would you turn off the MAF during tune? I would assume that the MAF is a component of the AF
Old Apr 28, 2013 | 03:13 PM
Driwash's Avatar
Driwash
What did he find? What did you end up with?
Tom
Old Apr 28, 2013 | 03:31 PM
tom01ss's Avatar
0tom01ss
Former Vendor
on a manual car you can adj fuel by playing with the maf. speed density turns the maf off, the maf measures airflow , everything needs to be tuned together in order to work together. you cant do one without the other.
